Question about Canon PowerShot S90 Digital Camera
Canon s90 can't focus to infinity
I replaced the lens on my camera, but it still won't focus to infinity. is there a way to calibrate or reset the camera?
  • 7 Answers
SOURCE: Canon digital camera will not focus
Check your diopter adjustment. It should be a small wheel on the upper right of the viewfinder. It is designed so that people who normally wear eyeglasses can use the viewfinder without their glasses, but it can occasionally get bumped. If the diopter adjustment is way off, it is like looking through someone else's eyeglasses!
Posted on Mar 18, 2008
darntoothysa
  • 489 Answers
SOURCE: canon ixus 75 digital camera reset?
Hi
What you are seeing is just an error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Posted on Apr 14, 2009
SOURCE: Canon PowerShot A420 reset lens error message
Not a solution, but a smilar problem with Canon Power shot A2000IS. Same lens error. reset camera message. Lens alos in fully open position.
Also in Costa Rica.
Any suggestions?
Neil
Posted on Jun 26, 2009
  • 164 Answers
SOURCE: My new Canon SX100IS is having "Lens error, Restart Camera" error
It seems the lens assembly has an internal problem and needs to be repaired.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
The reason of it it may be a spring or a metal post located in the focus sub-assembly, but the only way to confirm it is opening the camera and the lens assembly.
Best regards,
Posted on Jul 22, 2009
SOURCE: lens stays open, won't retract when camera turned off
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
regards iversh
a very helpful rating is apreciated for answering ur query.....
Posted on Aug 19, 2009
How to repair or unstick Sigma K zoom 100-200mm macro - tele focus stuck at infinity
Remove the lens from the camera, set MF on the lens, try gently to free it by hand. If this works, clean the contacts on the lens and camera body - if not, it needs repair.
Jun 05, 2017 | Canon Cameras
I have a Cannon 40D 28-135mm lens. With the lens in auto focus, the lens will act as if it has found the target will focus, beep, ready to shoot. The lens then makes a focusing sound and moves just a...
Does the camera still work even thought it does a small extra adjustment?
Are your pictures fine and is the camera working ok otherwise?
If your pictures are good then theres noting to worry about.
if on the other hand you can't take pictures, try reseting the camera, there should be a small reset hole in it.
Jul 04, 2008 | Canon Cameras
S90
if the camera makes all the sounds whilst trying to pop the lens out then you may have to get it sent to by Canon. I had the same problem with my old Powershot and it cost me nearly as much as a new camera.
Mar 23, 2013 | Canon PowerShot S90 Digital Camera
Canon lens won't focus
If it focuses OK in manual but not in auto then you may have broken ribbon cable in the lens.
Jan 20, 2013 | Canon EF 24-70mm f/2.8L USM Lens
Will not focus at a distance
Is the camera perhaps set in macro or manual focus mode? I've made that same mistake myself. If it is in macro mode then you will see (somewhere on the display) a small icon of a flower. If it is in manual focus mode then you'll see an MF icon.
Hope this helps
Sep 23, 2012 | Canon PowerShot S90 Digital Camera
I have been given a vivitar 70-210 series 1 lens 1:3.5 with a Canon AE1 would the lens work with a DSLR Nikon D3100 - would I need to buy an adaptor ?
No, and no.
The lens will not work on a Nikon camera.
Nikon cameras are deeper than Canon cameras. Even if a Canon lens fit onto a Nikon body, it would not focus at infinity. In order to enable a Canon lens to focus at infinity on a Nikon body, a lens adapter would have to have a negative thickness.
Sep 12, 2011 | Vivitar 70-210mm f/2.8-4 for Nikon AFD
Want an adaptor for a Nikon D80 to fit canon lenses
Not realistically possible, due to the incompatible lens to focal plane distances. If you found one it would either not allow infinity focussing or would need to incorporate corrective optics which add cost and ruin image quality.
All such adapters mean that the AF won't work, and focussing and image composition must be done with the aperture fully open before manually closing the aperture down to the desired value for metering and shooting. With Nikon G lenses the aperture is fully electronic, so the lens would only be operable at its smallest aperture.
You can get an adapter to allow Nikon to Canon EOS though, but as both cameras have plenty of excellent quality new and used lenses and resale values are high it's a pointless exercise.
Jul 26, 2011 | Cameras
Can you fit canon eos 888 lenses on nikon d3000
No. Nikon bodies are slightly thicker than Canon bodies. This allows a thin mount to adapt Nikon lenses to Canon bodies and still allow focusing to infinity. While an adapter for Canon lenses to Nikon bodies is theoretically possible, it would not allow the lens to focus to infinity. Thus, no one bothers to make one.
If you have access to a good machine shop...
Mar 08, 2010 | Nikon D3000 Digital Camera
Focusing to infinity
Hey redbarnz,
If the lens won't focus to infinity then there is probably something physically wrong with the lens. With the dominance of digital equipment you can find fantastic deals on manual focus 35 mm lenses. I would look at Canon manual focus lenses rather than sticking with vivitar. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 25, 2008 | Cameras
The auto focus on my 35mm lens is not working - Am desperate as working in remote, dangerous area of Africa
Dear Carol484:
The autofocus mechanism in your camera and lens is very complicated and can get out of "calibration" causing AF problems. Of course there are external factors that can cause this as well (dust, moisture, shock, etc). In Africa these external factors may come more into play than usual.
Of course the first and obvious remedies to try includes such things as:
1. Cycling your AF/MF a couple of times (switch it back and
forth a few times to see if it helps)
2. Removing your lens from the camera body and cleaning the
metal contacts there (preferably with an electrical contact
cleaner, but an eraser will do in a pinch)
3. Performing a hard reset on your camera (Resetting the set-
tings to default, removing the batteries for a few minutes,
and then reinstalling them)
If none of these help, use your Manual Focus until you can have the lens sent into a Canon Service Center for calibration and possible repair. Good luck.
Sincerely,
HeavyDLB
May 31, 2008 | Canon Cameras
Canon PowerShot S90 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
