Question about Canon PowerShot S90 Digital Camera
Canon s90 can't focus to infinity
My s90 couldn't focus to infinity, so i replaced the lens. new lens, but same focus to infinity problem. is there a way to calibrate or reset the camera? the lens works and sounds great except for the infinity focus poblem
  • 7 Answers
SOURCE: Canon digital camera will not focus
Check your diopter adjustment. It should be a small wheel on the upper right of the viewfinder. It is designed so that people who normally wear eyeglasses can use the viewfinder without their glasses, but it can occasionally get bumped. If the diopter adjustment is way off, it is like looking through someone else's eyeglasses!
Posted on Mar 18, 2008
darntoothysa
  • 489 Answers
SOURCE: canon ixus 75 digital camera reset?
Hi
What you are seeing is just an error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Posted on Apr 14, 2009
fotomohamed
  • 321 Answers
SOURCE: Canon SD 750 : "Lens Error, restart camera"
lens circuit got crack replace it
Posted on Jun 19, 2009
tommya300
  • 724 Answers
SOURCE: Canon Powershot SD1000 Lens won't focus
If you can get a hold of some dry nitrogen and setup a vacuum bottle of some sort using the food vacuum storage bag machine. Place the camera in the bottle. Seal the bottle with a top that has a dual vent idea where they both have a valve shutoff . One to the vacuum one piping in the nitrogen. Nitrogen is a no lethal non flameable drying agent they use in Binoculars to prevent fogging of the inside lenses.. Shut the Nitrogen side gas off. too. Open the vacuum side and pump down as much as possible there will be a max I do believe minus 25 foot pound per cubic inch of Mercury! Nature of this beast. Now shut that valve the camera is now vacuum packed. Turning on the Nitrogen open that port to the vacuum slowly not to make a sudden pressure change and let in all the Nitrogen it will take without blowing off the cap! If it is a pickle jar the top will pop like opening a sealed jar of pickles. .
Any moisture the nitrogen touches will be removes. This can be done if the camera's parts are not air tight. If they are then this problem would never had happened...
Simple and a cost of a very small jar of compressed Nitrogen is way less than 40 dollars. The vacuum machine should be a household item since you can afford a digital camera because you do preserve food and leftovers in savers bags
Posted on Jul 25, 2009
SOURCE: lens stays open, won't retract when camera turned off
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
regards iversh
a very helpful rating is apreciated for answering ur query.....
Posted on Aug 19, 2009
How to repair or unstick Sigma K zoom 100-200mm macro - tele focus stuck at infinity
Remove the lens from the camera, set MF on the lens, try gently to free it by hand. If this works, clean the contacts on the lens and camera body - if not, it needs repair.
Jun 05, 2017 | Canon Cameras
S90
if the camera makes all the sounds whilst trying to pop the lens out then you may have to get it sent to by Canon. I had the same problem with my old Powershot and it cost me nearly as much as a new camera.
Mar 23, 2013 | Canon PowerShot S90 Digital Camera
Will not focus at a distance
Is the camera perhaps set in macro or manual focus mode? I've made that same mistake myself. If it is in macro mode then you will see (somewhere on the display) a small icon of a flower. If it is in manual focus mode then you'll see an MF icon.
Hope this helps
Sep 23, 2012 | Canon PowerShot S90 Digital Camera
I have been given a vivitar 70-210 series 1 lens 1:3.5 with a Canon AE1 would the lens work with a DSLR Nikon D3100 - would I need to buy an adaptor ?
No, and no.
The lens will not work on a Nikon camera.
Nikon cameras are deeper than Canon cameras. Even if a Canon lens fit onto a Nikon body, it would not focus at infinity. In order to enable a Canon lens to focus at infinity on a Nikon body, a lens adapter would have to have a negative thickness.
Sep 12, 2011 | Vivitar 70-210mm f/2.8-4 for Nikon AFD
Tried to take pictures of lightening last night and couldn't. My lens kept going in and out and wouldn't focus so wouldn't allow me to shoot. Then I kept getting a BUSY across the screen. ...
For this kind of pictures, Don't try to focus on a lightning, it is to quick and mabe the overall brightness is not enough for your camera to focus.
So you can try to focus on something at infinity, if you manage then, put your focus on manual before re focusing, this way you will be able to take as many pictures as you want.
You can also try to focus manually directly.
And for you information the best way to take a lightning picture is to put your camera in bulb mode, use a remote control, open the shutter and close it as soon as you'v seen a lightning.
Hope this helps.
and good shooting !
May 27, 2011 | Canon EOS 500D EOS Rebel T1i Digital...
My 17-85 is no longer capable of focusing to infinity. It focuses short and medium distances with no problem, but I have to use manual focus to take long distance shots. Does the lens need to be replaced...
Depends on whether it is still in warranty. If so, check with Canon for warranty repair. If not, I'd guess it will not be cost effective to repair it, but a local (maybe one in your area?) Canon authorized shop could give you a better idea about whether to repair or replace.
Sep 30, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Can you fit canon eos 888 lenses on nikon d3000
No. Nikon bodies are slightly thicker than Canon bodies. This allows a thin mount to adapt Nikon lenses to Canon bodies and still allow focusing to infinity. While an adapter for Canon lenses to Nikon bodies is theoretically possible, it would not allow the lens to focus to infinity. Thus, no one bothers to make one.
If you have access to a good machine shop...
Mar 08, 2010 | Nikon D3000 Digital Camera
Focusing to infinity
Hey redbarnz,
If the lens won't focus to infinity then there is probably something physically wrong with the lens. With the dominance of digital equipment you can find fantastic deals on manual focus 35 mm lenses. I would look at Canon manual focus lenses rather than sticking with vivitar. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 25, 2008 | Cameras
Sigma 24-70 2.8 EX DG AUTOFOCUS PROBLEM
I would send it into sigma. They are in NY,
They are really quick about checking things out and I have neverhad them charge me to look at a lens and tell me whats up. aot of times they will just fix it while it there is it looks like something is worn out from normal use.
its a great lens. Some would say its a slower focus. than the Canon brand and you do get what you pay for but its hard to spend as much on canon lenses as they want. :)
Hope that helps,
Caleb
Jan 25, 2008 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
Unsure of how to use the extra functionality
That is the focusing ring. I'm guessing your camera is set to focus automatically (Little switch on the side of the lens should have settings for either AF or MF, or something similar.)
If its on AF, you don't need to adjust the focus ring.
However, if you have problems with the AF (sometimes it has trouble, especially in low light) you can switch it to MF, and focus manually by changing the ring.
As a general guideline, the more you twist to towards macro, it focuses closer and closer, and infinity futher away (if you're taking a shot of the moon, you want it on infinity)
Nov 26, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon PowerShot S90 Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
