function/original sixe ledger/#3 buttons in the sequence very quickly without releasing the buttons until all 3 are pressed. need 2 hands to do this. then service mode #7/maintenance counters/then web set to 239500.
Open and close the document feeder (where you put your pages that you want copied), take out any papers on there and place them back in the document feeder. press the start button. Good luck !
Hi friends, please check the dc adapter voltage,And battery also. Ensure the adapter light is gong on, if ok condition, please measure the voltage. Voltage will be E1705 DC Car Adapter (20V/6A 120Watts) check it.If not work please purchase from
for you to reset to factory default you must have the original cd that came with it, it's called PS admin Version 3.0 the process takes a second to gain your Print server back to factory default.... if you want it reply to this with your email address i will forward the executable file to you...
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
To paraphrase,
First try logging in with the following
username: psadmin
password: SYSXXXX
(where XXXX is the last four digits of the mac address)
If it works, you can proceed to reset the password.
