Question about Sony Televison & Video
Eneral Electric 19GT243 chasis TX808R
Tuner
What do I do when there is no picture and sound coming from my tv
Sounds like a tuner fault. Contact any service technician to make it confirm, and to replace. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 13, 2014 | GE 19GT243 19" TV
Tv has blue screen
You may have a bad ground in your tuner board! Or it may be a bad cable connection [the coaxial cable itself] Be sure you checkout your connections, cables, vcr,dvd etc. before you take the cover off the back of your TV. Thanks for asking!
Jun 09, 2010 | GE 19GT243 19" TV
I need a GE 19GT243 schematic General Electric 19 inch Television
Did you try Sams Photo Facts. Try looking under a model number as well as chassis.
Mar 22, 2010 | GE Televison & Video
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
Apr 19, 2009 | Televison & Video
Need to reset v chip on ge tv 19gt243
Reset the password to '0000' by holding the VolumeDown and ChannelUp buttons on the TV (not remote) for about 5 seconds. Do this while viewing blocked content- you'll see the screen blink when it gets reset. Then go into the menu and disable/change the v-chip settings as desired using password '0000'. Hope this helps- -sv-
Apr 10, 2009 | GE 19GT243 19" TV
Rca
This is typically caused by poor ground connections either at the cable input or inside the tuner itself. Check all external cable connections for good grounds. If those are good, then the tuner needs to be examined carefully for poor solder connections at the grounds.
Dan
Nov 28, 2008 | Televison & Video
How to hook up VCR
Without line out connections on the DVD/VCR unit and line in or RF modulator for the back of the TV in question, that cannot be done...accordianman
Feb 09, 2008 | GE 19GT243 19" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
