Question about Yamaha 2006 Apex RTX
2007 yamaha apex 1000 engine warning lights on
How to remove a gas tank on Yamaha Apex 2007
You have to remove the 2 bolts holding the seat down under the tunnel first. Then slide the seat to the rear to remove it.
Then you can remove the springs holding the hold-down plate on the rear of the tank. Just slide the tank back then.
Sep 04, 2017 | Yamaha 2006 Apex GT
Yellow light keeps comming on on my 2007 yamaha apex
Hi, Charles it should be noted that the reasons your check engine light constant or flashing, will or will not start, turns over or not conditions varies from the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work or event IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
1. Faulty Fuel Pump, fuse or system relay switch.
2. Battery starting to fail due to old age/damage, perform a load test.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
5. Broken wire or worn insulation exposing wire to a ground situation especially inside wire harness at tight bends around fairing brackets, under dash panels, under fuel tanks over cylinder heads etc. Many harnesses are open on the ends that will allow water to enter and accumulate at v-bends.
6. Check for generated fault codes.
Dielectric grease and contact cleaner are your best friends for wire/cable/harness connectors, look for corroded, broken, or loose pins/sockets.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Yellow warning light comes on apex but nothing else
Check engine symbol Came on with yellow light
06 10 apex service pdf PDF Archive
OEM parts for Yamaha
Yamaha RX10J Owner Manual
Dec 20, 2016 | Yamaha Motorcycles
My warning light on my Apex 2009 is on Fluids topped up What's wrong
the floater or sensor part got stuck for the cold or you mixed many different brands of fluids
Jan 24, 2015 | Yamaha 2009 Apex LTX GT
Engine trouble warning light
The check engine light signifies a problem....it may be small at this
time so have a diagnostic and prevent it from becoming big and
costly.
Regards,
Dennis
Sep 05, 2014 | 2007 Yamaha TMax
It wont turn over and the red engine light is on
The red engine light is a low oil warning light,thrashed sports bikes can drink oil so check level is correct,between the marks on the dip stick ,on level ground. most engines have an emergency cut out when oil to low.
Feb 14, 2010 | 2007 Suzuki GSX-R 1000
Oil light comes on when presing start button
Sounds like normal opperation, as long as it goes out after the engine is started. While cranking, the pump is still building pressure, and causes the oil pressure warning light to come on or flicker.
Aug 21, 2009 | 1989 Yamaha FZR 1000
2007 Yamaha FZS 1000 Fazer wiring diagram
Hi, www_jaydar3d for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 Yamaha FZS 1000 Fazer wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha FZS1000N Service Manual
Yamaha FZS1000N Owner Manual
Mar 28, 2009 | 2005 Yamaha FZS 1000 Fazer
Yamaha YZF 1000 Starting Problems I have a problem starting my FZR 1000. When i turn the ignition on and press the start button, the red oil light comes on and the engine does not turn over... I am...
sounds to me that it could be a faulty wire....it may not be grounded right. follow the negative wire from the battery.check it and make sure the insulation is not cut anywhere.check that the wire on top of the starter is good and tight also.
Mar 21, 2009 | 1989 Yamaha FZR 1000
Yamaha 2006 Apex RTX Logo
110 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
Gene Tuck
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
