Question about Mitsubishi WD-73737 73 in. HD-Ready TV
How to clean the filter on a Mitsubishi WD 73737
How do you clean the filter and where is it located
bshldn
  • 736 Answers
SOURCE: I have a Mitsubishi WD-73737
I've seen that happen on equipment that has automatic signal detection. Usually this option is available when connecting the equipment with an hdmi cable. The setting can either be on the television or the cable/sat box or both. You have to disable the automatic signal detection signal on both the television (if the television has one in the setup hdmi menu if there is one) and on the cable/sat box. Further you have to choose a resolution on the cable/sat box normally 1080i or 720p fixed. Disable the 4:3 override if there is one. Save and lock in the settings and you should be all set.
Posted on May 07, 2011
lovejoy91
  • 691 Answers
SOURCE: My mitsubishi wd-73737 continues to
Lamp or temp light comes on it can be the lamp or ballast, if you change the lamp I would do the whole cage instead.
Posted on May 22, 2011
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WD- 73737 73 in. Screen if dim or dark. Changed contrast, brightness, and restored default settings but that didn't work. Help?
I am not sure about your model but a call to Mitsubishi to ask if the set has one or two mirrors would offer a possible explanation---the ones with two mirrors have a small one at the bottom--it gets coated with dust and brightness drops up to 75 percent----other possible reason is the lamp may be nearing the end of its life.
I would have Mitsubishi look to see if this model uses the two mirrors--if that is the case cleaning will cure this--if you find it has two mirrors I can tell you what is involved--on Vacation but do look here--let me know what you find.
Posted on Jun 26, 2012
gopakumarg43
  • 75476 Answers
SOURCE: I have a Mitsubishi DLP WD-73737 65
What is the problem you faces with this set? Provide more details please.
Posted on Jul 17, 2012
SD Tech
  • 14553 Answers
SOURCE: How do i reset a Mitsubishi WD-73737 73 in.
The green light blinking is the set trying to boot up especially if power lost---70 seconds and should stop. Here is a link to a question I answered that might be helpful:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Posted on Aug 28, 2012
Mitisbuski 73737 made popping sound and cut off
Check your lamp. The popping sound was most likely the arc tube exploding. Make sure you only install a real Philips or Osram lamp. WD73737 Mitsubishi Genuine High Quality Original Projector Lamps now...
These folks have good lamps.
Apr 28, 2015 | Mitsubishi WD-73827 73" HDTV DLP TV
Error code 61 on WD 73737
Retired tech says, may be one of the fuses/resistor/transistor in unit blew out. reset won't work
Aug 28, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
Jul 16, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
Jun 26, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Mitsubishi WD-73737 73 in. HD-Ready TV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
