Rank: Guru
Rating: 87%, 203 votes
The 192.168.0.1 is the device IP.
Your trying to change the "Default Gateway" mine is set to 192.168.1.1
Let me explain (:
1.Go to start>run>type "cmd" without quotes and press enter.
The black screen should appar, in that screen type "ipconfig/all" without quotes.
And press enter.
This is what mine looks like:
I took out some things to my security, but basically this is what some of these things represent.
For you, your IP it shows would be something like:
192.168.1.101
Each device hooked up to your network gets its own IP it will start at 192.168.1.101 for the first device, then 192.168.1.102 then the next device gets 192.168.1.103,etc...
Your default gateway, 192.168.1.1 is where it starts, to change this go to:
- Open your browser
- Type in the browser 192.168.1.1
- Login to your router panel (the user an pass sometimes are admin/admin look in your manul for more info)
- Look where you can change your default gateway.
Here is a example of what mine looks like:
I hope this educated you, and helped you fix your problem for more help visit www.pc-fix.us or just reply here.
Thanks,
Cam
