Question about Vic Tokai, Inc. Trouble Shooter for Sega Genesis
Maytag belt problem
Drive belt broke, replaced it with new maytag belt. washed a load, adjitated ok, but when it switched to spin cycle it burned the belt off.
    Problem Solver:
  • 13 Answers
Sounds like a partially seized component. The belt will work under average load, but when it reaches spin cycle where it must run at high speed it may be encountering too much resistance from the component that it is spinning. Was there a whining or squealing sound? Did you notice any smoke or odour? Perhaps a failed bearing may be to blame, or an errant piece of clothing. My machine is a Maytag front loader and I can easily turn the drum with my fingertips. I don't know what machine you have, but basic mechanics tells me that the motor is spinning and the piece the motor is trying to spin via the belt is resisting. Hope this helps. Cheers!
Posted on Aug 21, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Won't spin at end of cycle. Maytag top load washing machine
RITS REAL COMMON WITH THAT MODEL FOR THE BEARING TO LOCK UP. TURN THE TUB BY HAND A LITTLE THEN TRY SPIN, IF IT THEN RUNS YOU NEED A BEARING/SEAL KIT.GOOD LUCK
Jan 16, 2010 | Maytag SAV5710 Top Load Washer
Wash cycle dose not work
There is a small white micro switch mounted near the lid switch. This is a called a check switch. Replace it.d023fa4.jpg
Jan 08, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Burning Smell when spinning
8 yrs old....The LATs were the best models for Maytag...Maybe it's time to replace the belt..Slipping belts smell bad.
Jun 09, 2008 | Maytag Dependable Care LAT9416
Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
Oct 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
MAYTAG WASHER SAV205DAWW
i can step you through it in a live chat session
Sep 27, 2007 | Washing Machines
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Vic Tokai, Inc. Trouble Shooter for Sega Genesis Logo
57 people viewed this question
Top Vic Tokai, Inc. Video Game Consoles & Games Experts
James Wishart
Are you a Vic Tokai, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
