Question about Kenwood Dishwashers
I am getting an e1 on my kenwood KDW60S12 dishwasher
Have you got any solutions
sbshardcorps
SOURCE: e1 fault on kenwood dishwasher kdw243a
error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
Posted on Jul 14, 2009
GodBlessU
  • 3513 Answers
SOURCE: e1 error code on my kenwood dishwasher [kwd243a
Hi
The E1error code indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, it is much more likely to be flow meter .
Thanks for contacting fixya.com
Posted on Sep 10, 2009
  • 16 Answers
SOURCE: wont go on to programme when switched on starts
Check that you have tuned on the inlet water tap(faucet usa).
Posted on Jan 24, 2010
  • 16 Answers
SOURCE: kenwood KDW12ST3A
E1 indicated long filling time. Perhaps the inlet filter has clogged. Check the inlet pipe and tap(faucet in usa).
SOURCE: kenwood dishwasher showing e1
fault E1 in manual states no inlet pressure. sometimes fault code shows if machine takes too long to fill. check for blockage in inlet pipe.
Posted on May 09, 2010
Kenwood KDW60S12 Dishwasher manual
Water is not heating up and not drying !!! Only had a month
Dec 10, 2013 | Dishwashers
E1 ALARM ON KENWOOD DISHWASHER
An E1 is a control board error. Sometimes it can be soldered at the heat element relay which get hot often and can melt the solder ion the board. It is fairly easy to replace a control board.
Feb 07, 2011 | Kenwood KDW243A Builtin Dishwasher
E1 fault on kenwood dishwasher kdw243a
Jan 18, 2009 | Kenwood KW85 Air Conditioner
Dishwashers Logo
Top Kenwood Dishwashers Experts
Oloyede Monsuru
ashburton
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
