Question about Samsung Washing Machines
Samsung q12355 dei error - Samsung Washing Machines
Is it possible to change the color of a rubber sole, what paint should i use?
the colour full rubber of sole and dei are diffren diffrent colour in a market
Apr 12, 2017 | The Clothing Accessories
How many Horse power Dei-815/E freezer
Freezers are not measured in horsepower, only mechanical engines. This is the specs, and it is basically a 25 amp freezer, with an additional 7 amps or fans lighting and door heater, both at 250 volts AC. However, running an Amps to HP converter gives 6.971 horsepower.
DEI-815 dual controller with external probe box d
  • DEI-815 dual controller boxed With external probe
    Set Temperature range: -40 to +40
    Tolerance of 1 ° C
    Contact compressor outlet 25 Amp. 250 VAC
    25 Amp Output contact resistances. 250 VAC
    Contact Fans, lighting and perimeter heater 7 Amp. 250 VAC.
    Connection 110- 220 V 50/60 Hz.
    NTC sensors 02 1.5 mt.
Mar 16, 2016 | Cars & Trucks
Hey MECP guy, what a job you're doing; THANKS. I want to buy the Prostart CT-5472W for a 2004 Lincoln Navigator. I also want to get addt'l modules like DEI 504D shock sensor 506T audio sensor
Yes, I frequently use DEI modules with Audiovox( Prestige and Code) alarms and remote starters. I just have to hardwire them to work with the systems.
Oct 26, 2012 | Vehicle Parts & Accessories
I have a horn that sounds when my hay baler chamber is full. I am looking for a timer relay that will allow the horn to sound for 3 to 5 seconds and then disconect the circuit so it won't drive me...
DEI 528T appears to be 12Volt 'wait to start' or ON-delay timer.
528 receives electrical signal, and then delays the start-circuit by up to 60 seconds.
For example home alarm system. Door is opened and alarm sounds. Install DEI 528 and set for 60 seconds: Door is opened and alarm will not sound for 60 seconds.
You need 12-volt off-delay timer.
Off-delay timer receives electrical impulse, and then begins a countdown.
After countdown expires, then circuit turns off.
ELK-960 appears to have off-delay feature for 12V DC
http://www.homesecuritystore.com/p-423-elk-960-delay-timer-module.aspx
Use wiring diagram #7 for alarm cut-off:
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ELK-960_Install.pdf
Aug 25, 2011 | Directed Electronics Dei 528t Pulse Timer...
Ciao e stata bagnata una telecomanda tv samsung e non funziona piu ! cosa faccio?
si dovrebbe fare è cercare di aprire il telecomando, pulita fino a secco.
se c'è una connessione carbone manca, non funziona più.
controllare e sostituire il batery a causa dei danni. speriamo di aiuto.
Mar 16, 2011 | Samsung TV Remote Control
Hi what tupe of starter i should purches for my car i have santa fe 2002
It really depends on what features you are looking for. I installed Audiovox for 12 years and DEI for 8. I like the DEI much better. The Audiovox always had problems with their remotes and would break down. DEI remotes last much longer and all the options are better on it too. They are the leaders in the field.DEI is the makers of Viper and Python as well as automate.
Nov 12, 2010 | 2000RS-M Remote Starters Manual...
I have a DEI 471T remote start/lock. The parking
There is a white wire coming from the alarm, there should be a blue 15 amp fuse in that wire, close to the brain for the alarm. It sounds like you have blown that fuse.
Aug 10, 2009 | Directed Dei Valet 561r Remote...
What fuses does it take? Have it in my car but there are missing fuses also have other dei products in my car that are wired but missing fuses. Please help!
I'm still digging but I have some info for you. DEI- 530 is a Window automation system. DEi- 529 Is a window roll up module. DEi-520 is a battery back up.
May 04, 2009 | Honda Civic Cars & Trucks
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
