Question about Panasonic KX Office Equipment & Supplies
Kx-bp635 prints stripe down page
We have a panasonic KX-BP635 printing whiteboard. When it prints the contents drawn on the board, the belt rotates as normal. However, the printout contains a horizontal stripe which is completely opaque. This stripe appears on every printout regardless of contents drawn on the board. Do I have something (like a piece of paper or tape) that somehow got stuck within the board itself? Or does this mean I have a bad print head?
SOURCE: Horizontal stripes on images
I tried even to exchange my printhead and it did not help.. The service said its a printers problem not the ink or printhead.. but they did not came up with a solution :C
Posted on Apr 30, 2008
Maanita
  • 1142 Answers
SOURCE: Sharp VB-291 Electronic Whiteboard. Not getting
Thank you for posting your concern details however i would be
needing few more details from your side if necessary and
allow me few mins to come up with the resolution.
Posted on May 14, 2008
SOURCE: i just bougt Panasonic KX-P1150
same problem
Posted on May 20, 2008
leroyal
  • 2120 Answers
SOURCE: We have a Panasonic KX-B530
Change the paper first, but it sounds like you have a bad THERMAL HEAD.
Posted on Dec 04, 2008
  • 215 Answers
SOURCE: Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Posted on Apr 13, 2009
I need a manual for a Panasonic KX-TGP500 SIP Cordless Phone handset ?
hi Beth.
go to this link and this should be the manual.
https://www.voicesonic.com/panasonic/manuals/panasonic-others/TGP500-550-Admin-Guide.pdf
if this is not the manual you are after go to this link and scroll the page there is more manual there.
manual for Panasonic KX TGP500 SIP Cordless Phone handset Google Search
Nov 21, 2017 | Panasonic Lands Phones
I work for a deskside support team and we have a panasonic kx-bp635 error code 5 coming up...
Can you give more details?? Very little goes wrong with these whiteboards. Are you sure its a KX-B635??- Ross
May 27, 2011 | Panasonic Panaboard KX-B635 (KX-BP635)...
Is there laser fax model 612? Its the same as 611 or not?
Yes those Panasonic models are the same just the KX-FL 612 is different from KX-FL 611 in some specifications like as example:
611 prints maximum 14 pages per minute and 612 prints 16 pages per minute. The document feeder on 611 can feed maximum 20 pages while 612 can feed 30 pages and some other compare stuff like those.
Mainly KX-FL 612 is improved version of KX-FL 611
Jul 11, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic kx-f1100 fax prints and sends 1 page on 2 pgs- 2big!
I found the solution to my problem: Press Menu, Pound Key (#), 35 to set copy size, 36 to set fax size, press Start/Set, then use up/down arrows on right side of the machine to select 92%, 86%, 72%, or Off. Press Start/Set to select desired setting.
Press Menu to exit!
Dec 08, 2008 | Panasonic KX-FP81 Plain Paper Fax
Panasonic KX B520 does not ptint
I'm not sure if this will help, but we pulled my Panasonic KX-B520 printing whiteboard apart to find out why it didn't print. After a couple of hours and much head-scratching we figured out the paper was in the wrong way around. The printer was working fine, it just couldn't print on the wrong side of the paper. Even though the diagram on the inside of the paper bin showed the the print side of the paper on the outside of the roll, this particular paper roll had the print side on the inside. Answer? Put the paper in the other way around. It works a treat.
To see which side your paper prints on, hold a match or lighter to one side of the paper and see if it goes black from the heat. One side will, and the other won't (well, it will burn, but not like the other side. Use your common sense here.) The print side of the paper should contact the horizontal metal strip at the top of the paper holder bay.
Good luck. I hope my answer works for your problem, because it's so easy to resolve.
James from Canberra.
May 03, 2008 | Office Equipment & Supplies
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
