Question about Roper REX3614KW Electric Dryer
My Roper dryer model #RGD4440SQ0 is not heating up
  • 159 Answers
SOURCE: roper dryer won't heat
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Posted on Aug 22, 2007
  • 163 Answers
SOURCE: My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
onthejob5130
  • 640 Answers
SOURCE: dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Posted on Dec 28, 2008
TheMobilian
  • 8220 Answers
SOURCE: roper dryer model res7648kq0. wont turn on or heat ?
On the back side of the dryer sits the heater and various safety clixons. Any of them that would be OPEN ( no continuity) would be the problem. Here are some repair pictures
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 25, 2009
rogrrabbit
  • 986 Answers
SOURCE: My dryer roper model number
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
Roper model res6745pqo ser.ms4808124 dryer Dryer works except no heat
You have a bad heater element, or high limit/thermostat. Check your vent for restrictions also. A restricted vent will cause higher heat and thus reduce lifetime on these componants. Rich
Oct 01, 2010 | Roper RES7646KQ Electric Dryer
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
I have a roper dryer Model RES7646KQ2. While I
Sounds like thermal cut off fuse has blown. That is indicative of airflow obstruction somewhere either internally in the dryer or venting from dryer to outside v
Nov 15, 2017 | Roper REX4634KQ Electric Dryer
Noisy Roper RGD4440SQ0 that won't get hot
The two problems are not likely to be related, for better or worse.
The drum is supported by rollers and one of yours has failed. This may be a DIY repair.
The lack of heat is caused by the failure of the ignitor, which in most cases, is a ceramic device with a heating element that ignites the gas and it has failed. I have done these and they are generally not dificult to replace but depending on the construction, the entire housing may need to be removed. This also isn't that tough and doesn't require any special tools but it would be helpful to have two people at hand.
If you have a Johnstone Supply outlet in your area (check white pages), they should have the ignitor at ~ 30-50% of the dealer's price. Johnstone is technically 'wholesale' but I have never been turned away.
Aug 07, 2009 | Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Roper REX3614KW Electric Dryer Logo
51 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
