Question about Nikon COOLPIX L18 Digital Camera
Change resolution i ahve a nikon coolpix l18 with a 8.0 megapixel. i need to lower my resolution so the sd card i have can take more pictures and i can not seem to figure out how to do that... please help!!!
    President:
  • 423 Answers
Press the menu button and go into the image mode setting. Use the right arrow to go into the table of quality options. Use the up/down on the dial to select the file size (quality) you want. You will then see the quantity of images the card has room for, at the selected resolution.
Posted on May 23, 2009
Message says memory card is write protected and does not allow me to take any more pictures
What kind of card is it? An SD card? If so, there should be a little tab/switch on the side of it that you can flick to resolve the issue. If not, have a look at this: How do you remove write protection from mini SD card
Sep 29, 2014 | Nikon Coolpix L26 16 Megapixel Digital...
Sd card is 32m it is only giving 12 images
A 32mb SD card doesn't have a large capacity - depending on the resolution (megapixels) of the camera, a different amount of pictures can be stored. Below is a link to a page that can help you determine what size is right for you.
http://www.sdcard.org/consumers/cards
Mar 06, 2011 | Canon PowerShot A495 Digital Camera
How much memmory support does it provide nikon coolpix p4 vr
The P4 has about 23MB of internal memory, which might hold five pictures at the camera's best resolution. The camera also accepts SD cards up to 2GB in size, which should hold several hundred pictures. And, of course, you can use multiple cards.
Jan 04, 2011 | Nikon COOLPIX L18 Digital Camera
Just received a mint condition Nikon Coolpix S4 swivel-head digital camera off eBay. Installed new AA alkaline (Duracell) batteries and a new 1GB SD card. From the firt time I fired it up this morning, all...
Without some detailed information on how the unit processes video vs. still images, it won't be possible to say for sure, BUT....
The video resolution is processed at a much lower megapixel setting than still pictures. It may be that the defect in the sensor that is causing the lines is on a section of the sensor that is either not used in video mode, or that the software is processing out the defect when it doesn't need all the pixels to give you an image. I think the first is more likely. In video mode, the camera has to run at a lower resolution so that the electronics can store information fast enough to give you video, so it uses a lower resolution. Since it's using the same sensor, it has to either ignore some of the pixels or just not sample them.
If it is the sensor (this is most likely but can't be sure without testing it), then the only way to correct would be a new sensor. It could also be a bad wiring connection, but either way you'd need to get inside to fix. That would be expensive.
I think you should try to use a lower resolution setting and see if maybe that will eliminate the pixels that aren't working. You won't be able to get the highest resolution from the camera, but megapixels are overrated. If you can run it at 3 megapixels or more, you'll be able to do just about anything with it.
Aug 31, 2009 | Nikon Coolpix S4 Digital Camera
How do I import pictures from my Nikon Coolpix s550 digital camera to a PC laptop?
You can either connect the camera to the computer using the supplied USB cable, or remove the SD card from the camera and insert it into a card reader attached to the computer. The card reader is the preferred scheme, as it does not drain the camera's battery.
Jul 11, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Adjusting Pictures Resolution
you use the function button while in camera mode and scroll to the image size then turn the function dial to change it. you should consider taking your photos on the higest resolution, however, because SD cards are very cheap and you can get 8GB cards for under $40. Your camera came with a 32MB card which is tiny--you should throw it away. 8GB will store hundreds of 9 megapixel photos--i recommend having at least two SD cards. i hope this helps.
Mar 12, 2009 | Canon PowerShot SX110 IS Digital Camera
Blurred picture with nikon coolpix 995 macro mode
When shooting in macro to get good depth of field you often have to shoot f/22. This does not let much light in. You have to hold the camera and subject tight. Meaning the use of a firm tripod is not optional. In most cases you need a longer exposure so wiggle is very important.
Jan 20, 2018 | Nikon Coolpix 995 3.3 Megapixel 4x...
Nikon COOLPIX L18 Digital Camera Logo
236 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
