Question about Intermatic T10404R - two 220 time clocks in rain tight box - Time Clock
Right side timer works fine, left one not working at all.
Timer not working T10404R Right side works fine, left side isn't keeping time at all, is not working at all.
5 Suggested Answers
  • 52 Answers
SOURCE: I have an intermatic t10404r pool timer, and only one timer works
The problem might be the trips.
Posted on Feb 25, 2010
SOURCE: The right side is for the pool sweep. The timer
If timer wheel doesn't rotate on time, then clock motor is probably bad.
Probably the wheel is getting stalled a bit when tripper comes into contact with on-off lever, because motor has lost power.
Add a bit of grease where tripper come into contact with on-off lever.
Intermatic T104 is 240Volt clock motor
Buy T100 series 240V clock motor from grainger:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Notice also that link above also shows extra trippers.
Trippers are designed to wear down before on-off lever, so timer mechanism lasts longer.
To install clock motor, snap mechanism out of box using thumb spring at top.
Motor is attached with 2 small star screws.
Notice that motor has plastic gears so motor is designed to stop working before rest of timer.
Motor wires attach to terminals 1 and 3, tighten screws very tight against copper wire.
Make sure no part of the wire insulation is under screw plate when tightening.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 26, 2011
SOURCE: HI My Intermatic T10404R has
Probably just the $18 clock motor, or $2 trippers.
Or buy timer-mechanism-only and snap into same box.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Apr 29, 2011
SOURCE: My ML200RTW isn't generating 12VDC
Bad news.
There are no repair parts for broken power pack.
Terminals A and B should test for 12 volts, as you have determined.
Terminals C is for photo eye operation only.
If transformer hums, that is signal that it is working.
It might be possible to open case and somehow find the copper wire from the transformer that will produce 12 volts again, but nobody has reported being able to fix power pack.
Please add a comment and say if you are able to do this successfully.
ML series power packs have 5 year limited warranty, and you usually need the receipt.
Open following link for troubleshoot steps plus warranty links, money-saving tips for next power pack.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
Posted on May 26, 2011
I have a T10404R dual intermatic timer clock and I can only turn my pool pump on manually. The clock is working and it will turn off, but I can't get the ON pin to work despite replacing it with a new...
1) Troubleshoot walk-thru indicates that tripper is wrong, or timer mechanism is worn out:
Check that tripper is labeled ON, and compares similarly with old tripper, and is not worn down. Trippers are made of softer metal and designed to wear out before the timer mechanism wears out.
http://waterheatertimer.org/images/WH-lever-005-500.jpg
2) Buy new timer mechanism: If the new ON tripper does not push the on-off lever, then timer mechanism is probably worn out.
Buy new T104M mechanism, and change out with existing mechanism using thumb spring located top inside box.
3) How it works: The trippers rotate around on clock dial. Trippers come into contact with on-off lever, and trippers push lever.
On tripper pushes lever one direction. Off tripper pushes same lever other direction.
Each time the lever moves back and forth, the manual override also clicks with audible sound.
The lever moves a slide bar located on back of timer mechanism, and that action opens and closes electrical circuit.
http://waterheatertimer.org/images/Back-of-WH40-2b-500.jpg
4) Since any timer mechanism can fit into the T10404R control panel, you can also buy and install T104M210 timer mechanism with fireman's switch that turns off heater 20 minutes before turning off pool pump.
For 2-speed pool pump, the digital P1353 can also be installed, and this timer would replace both timing mechanisms in the T10404R. Non-electronic timers are more reliable.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
5) Add a comment for more help
6) Take a moment and rate answer for accuracy:
Sep 18, 2011 | Intermatic T10404R - Two 220 time clocks...
Timer clock not working
Problem is not clear.
If this is new installation, then wiring is probably wrong.
Voltage and model number of timer is not known for certain.
You posted under T10404R that has 2 T104 240V timers.
Open following link for T104 wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment and describe your wiring.
If timer worked before, then you might need $18 clock motor
Open following link for troubleshoot checklist and instructions for replacing clock motor:
Upvote the help.
Jun 01, 2011 | Intermatic T10404R - two 220 time clocks...
HI My Intermatic T10404R has two timers (one for pool pump and the other for the polaris vaccuum). Unfortunately, the timer for the vaccuum is not working. Is there is fix for this or does the whole system...
Apr 29, 2011 | Intermatic T10404R - two 220 time clocks...
My pool sweep had been doing fine. Now the new pump seems to be dragging as if it is running on half power and the sweep crawls slowly. The pump gets hot and shuts off. The pool filter pump on the left...
My opinion is that new pump is defective.
You posted under Intermatic pool timer.
The timer will not have any effect on the new pump overheating.
Insufficient wiring can cause new pump to overheat.
However if wiring is undersized, and/or if both pumps are turned ON at same time, the circuit breaker would get hot and trip.
Instead of the breaker tripping, your new pump is getting hot, and turning off.
Remember, any pump that slows down and overheats is getting damaged.
Replace the defective pump.
Feb 28, 2011 | Intermatic T10404R - two 220 time clocks...
The right side is for the pool sweep. The timer wheel doesn't move around and keep in time with the left side which is for the pool.
Jan 26, 2011 | Intermatic T10404R - two 220 time clocks...
Can you fit a frost switch to the T10404R
http://www.poolandspacontrols.com/~/media/Files/PoolAndSpaControls/Products/Instructions/PF1102.ashx
http://www.poolandspacontrols.com/products/freeze%20protection%20controls/multi%20circuit%20freeze%20protection%20controls.aspx
Intermatic makes a freeze protection control that wires directly into a 240V timer.
If you already have a freeze control, the wiring diagram might help.
The manual has this image larger.
It shows wiring to connect the freeze control directly to one 240V timer.
Intermatic make a freeze control for 1 or 2 circuits.
Intermatic page showing Pool and Spa timers
http://www.poolandspacontrols.com/products/mechanical%20controls/100%20amp%20specialty%20control%20panels.aspx
Nov 11, 2010 | Intermatic T10404R - Two 220 time clocks...
The pump stopped working today. There is power to the pump and the circuits did not shut down. I think the clock could be bad. It has not moved so I feel the problem is the clock. the pump is new.
If you move the manual lever to the ON position the pump should turn ON. If the pump turns ON manually and the clock is not moving as you say, then, yes, the clock timer motor is bad.
Replacement parts are available here: (Cat# WG1573)
http://www.aplussupply.com/intermatic/timer.htm
Aug 29, 2010 | Intermatic T10404R - Two 220 time clocks...
Intermatic T10404R - two 220 time clocks in rain tight box - Time Clock Logo
78 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
