Question about Ford 555 backhoe
Alternator wiring have lost wiring diagram, need to know how to wire up the alternator with internal regulator
  • Ford Master
  • 2,478 Answers
Goggle diagram wiring 6v to 12v tractor
Posted on Jan 03, 2014
Thank you again alternator has been changed 3 times parts store's tell me that this system has external alt. so would it be located as part of the brain;s function
My confusion. Your previous post had me understanding you were saying the regulator was internal to the alternator. I have a 1999 Dakota and it has the internal regulator. I went back and looked at the wiring diagram for your model. The wiring diagram refers to your unit as a generator vice and alternator, and yes, it does get a controlling signal from the Power Control Module (PCM). It comes in on a dark green wire.
Mar 06, 2015 | 1991 Dodge Dakota
In need wiring diagram for Toyota Dyna 1.5 ton
ask toy yets?
what country, we cant guess that, big world and all, and all cars vary by, drum roll, country.;
Jan 07, 2015 | Toyota Cars & Trucks
Alternator Wiring Diagram
Usually the alternators possess one thick white colored wire directly coming out of the battery positive terminal (+) which is around 8 mm (outer diameter) and connects the battery with alternator and white or black 3 wires connector which is inserted at the rear of the alternator. If you look carefully at the rear of the alternator you will find the embossed letters there. Some time the letter may vary depending upon model year of the vehicle. Normally the letters describe L= Alternator warning LAMP in the in the instrument panel of the speedometer. B= 12 Volts coming out of the ignition switch on the ON position. G= Ground or chassis ground.
Nov 25, 2013 | Toyota Land Cruiser Cars & Trucks
Wiring diagram chevy need
Sounds to be internal voltage regulator in alternator failing. To verify this, have engine running and disconnect black negative wire from battery. If engine shuts off, replace alternator.
Nov 14, 2013 | 1993 Oldsmobile Cutlass Supreme
How to connect a new era alternator voltage regulator wiring diagram.Or a schematic diagram of the charging system.
knowing the color codes can be a great help..usually in 12v reg system,from the regulator there are 6 white wire having a stripe codes,blue means neutral,green means field,black means ground to body,white means hot wired to +12v,yellow means to bat charging indicator going to instrument panel and finally red means to ignition....and always secure the regulators case to ground.
Jul 19, 2011 | Isuzu i-Series Cars & Trucks
I typed in the wrong year i have a 1980 f 150 there was a short going from the solenoid to the starter.it fried the wires we replaced the wiring now it wont charge.can you give me some ideas on where the...
if it is not charging -- then the problem is the alternator. check the alternator ( at the alternator ) for output. if there is voltage there - then the problem is the wires between the alternator and the battery. this could be the voltage regulator ( if it is not a internally regulated alternator ). or it could just be a bad wire.
now if it turns out to be the alternator -- replace it with a internally regulated alternator,,, this will help simplify things in future diagnostics.
c...
Feb 11, 2011 | 1984 Ford F 150
Need wiring diagram for 1967 camaro v8 changed from external regulator to alternator with internal regulator
I am assuming you are now using a 1976 style GM alt.
The most common and popular model.
You need one 10 gauge wire from the battery to the alternator output.
This can be run directly from the battery +.
Run a short 10 gauge wire from alt output to large wire at regulator plug on alt.
Run small wire on alt reg plug to Bat light wire.
A new alt regulator plug pigtail can be bought at any parts store and is recommended.
The existing regulator should have the connections marked.
One of those wires will be the bat light wire if needed.
If you have a amp meter or voltmeter in the vehicle.....use your existing large output wire (usually red) to hook up to the new alt output connection.
Sep 15, 2009 | Chevrolet Camaro Cars & Trucks
Chevy G20 1985 wiring (charging problem)
http://wareznuke.com/apps/3872/all-1979-2007-vehicle-wiring-diagrams-v42-rapidshare-warez
Jul 07, 2009 | 1985 Chevrolet Sportvan G20
Garden Logo
429 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
