Question about Sharper Image Professional Plus Ionic Breeze GP (SI871) Air Purifier
I own four of the units and for some reason the small blue light on the right hand knob is blinking. I have cleaned them thoroughly. The turbo button works fine and you can feel the additonal air movement. They still all collect pollutants out of the air as they continue to get dirty. But the on off swich does not work as it just continues to blink on all four units. Thanks for any advice as the manual does not address this in the trouble shooting section.
    Top Expert:
  • Sharper Image Master
  • 76,649 Answers
Do u have an owners guide?, i believe this light is for the door that you remove to clean the collection grid.
Posted on May 19, 2009
Does the ionic breeze blow air
They only move the air slightly. They are not like a conventional fan.
They do not rotate.
They do work effectively for mold spores and dust. If yours has not been cleaned in a while remove the front element from above and spray the stainless bars down with an acidic claener like "Formula 409" and wipe them down after rinsing. On the unit itself unplug it and remove the front and rear grill br pressing a small tab at the bottom of the grille and push upwars. Be careful with front grille as there is an ionizing wire there towards the inside of the unit. If the unit has come from someone else, with an emery board and gentle pressure just make one pass witht he wire gently between board and your finger. drawing towards the spring loaded end. Do the same to the two wires inside the unit housing if present, Witht he rear grille removed, remove the bulb and wipe it down with a cleaner if needed- it should be clear. as it is a UV bulb.
Dust out hte base area with a small paintbrush and remove as much dust as you can from it. If need be a slighly damp rag cna also be used.
With the front of the Ionic breeze unit facing you, there are 2 conductive rubber strips that also need to be wiped down with a lsightly damp rag. They should be removing some black dust. Also wipe down the inside of the front being mindful of the two stainless wires.
Let unit dry off and reassemble.
With left knob turned to left- no light should appear. Turn knob to the right and the UV tube should light and the Boost button should light up blue when pressed once- and green when pressed a second time and then off if pressed a third time. It will only light when the left knob is turned to right.
The right knob adjusts "Low," "Medium" and "High" intensity of the high voltage applied to elements.
Alow unit to dry before powering it on.
A working system should raise the hairs on the back of you hand or give you some other sensation of moving air
Sep 29, 2012 | Sharper Image Ionic Breeze 3.0 Air...
The blue light blinks
I believe that a blue blinking light indicates that the stainless steel collection blades need to be wiped clean. The unit uses these blades instead of a replaceable filter. Simply wipe them clean with a damp cloth and you should be ready to go!
Jun 24, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Pro makes weird buzzing noise
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Jan 03, 2009 | Ionic Pro TURBO Air Purifier
The blue light on my ionic breeze is blinking.
The ionizers were recalled by Sharper Image due to a lawsuit that they lost forcing the company into chapter 11.
There is a thread on this website with further details.
Sep 13, 2008 | Sharper Image Professional Plus Ionic...
Blue lights are blinking
I have the small version Quatra our older unit finnally died so sharper image sent us this smaller version. This will be the 2nd or 3rd replacement with in a week of getting a repalcement everytime the light starts blinking before it can even get dirty.
Mar 20, 2008 | Sharper Image (V23145) Air Purifier
Excessive noise
Oct 26, 2007 | Ionic Pro TURBO Air Purifier
Problem
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Aug 05, 2007 | Sharper Image Ionic Breeze SI719 Air...
What does a blinking blue light indicate?
Jul 07, 2007 | Sharper Image Ionic Breeze GP SI720 Air...
Sharper Image Professional Plus  Ionic Breeze GP  (SI871) Air Purifier Logo
54 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
