Question about Husqvarna Sewing Machines
My Lily 535's info display is not fully lit up and I cannot get any kind of stitch except straight. Cannot lengthen or widen the stitch either.
This is a used machine that was supposedly gone over by tech before I bought it. Now less than 90 days later it isn't working.
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
kent581
  • 87 Answers
SOURCE: Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
Posted on Mar 19, 2009
SOURCE: machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Posted on Apr 17, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
How to lengthen out the straight stitch on a 1230 bernina
Use the Stitch Length dial/lever. The higher the number, the farther apart the stitches will be.
Feb 15, 2017 | Bernina Sewing Machines
I have a new elna 860 expressive today when I switched it on only some of the icons are lit up, the straight stitch and tea shirt icons. On the straight stitch setting only the top 4 icons are lit
Is it "brand new," ie just purchased from an Elna dealer? If so, take it back immediately! It is still covered under warranty.
Possibly some of the computer components are failing. This, most often, requires professional service.
Jun 14, 2016 | Elna Sewing Machines
I cannot get the green decorative stitches to work. I'm insure if my Bernina 930 is broken or I'm just unfamiliar with this machine. How do I set my machine for the embroidery stitches?
There are 2 levers on the top that need to be set. One shows the green stitch selections. That needs to be set to your stitch choice. To its right, there is another lever called the "changeover lever." It needs to be pushed all the toward the back of the machine--that switches it from straight stitch to decorative stitch.
Then on the bottom front on the right is a large knob. Both the outer ring of the knob and the inner knob perform different functions. One drops the feed dogs for darning or raises to activate the feed dogs to pull the fabric through the machine. The other part switches between the red and green stitch selections. When that knob is turned the light should show green or red to coordinate with the stitch selection lever on the top of the machine.
So to make decorative stitches, there are 2 levers that need to be moved plus the red/green activator knob. In addition, you will want to adjust the stitch width dial and the stitch length lever to widen or lengthen the stitch.
If you need a manual for your machine, you can download it free here:
BERNINA Support Machine and Accessories Finders and Software Support...
Apr 07, 2016 | Bernina Sewing Machines
Settings for standard sewing stitch
I can't see what model machine this is, however in general terms a straight stitch is achieved by setting stitch length to 2.5 with stitch width of zero. If you are sewing a very heavy fabric, then lengthen the stitch length up to three. If you make the stitch length longer such as four, then the seam will pull up and gather the fabric.
Feb 14, 2015 | Sewing Machines
How do i widen buttonhole stitches to make larger buttonholes?
Stop using the button hole program ! Use the button hole foot but do the stitch by hand adjusted satin stich ! Remember to lock off after each rib sewn !
Aug 27, 2014 | Sewing Machines
Bernina buttonhole 730
Use your ruler and measure your button. Then transfer those measurements to your garment.
Use chalk to mark the center cut line of your button hole. Mark the end or stop point of the button hole per the measurement.
Practice on a scrap of the same fabric before you begin on your garment.
Set your machine the satin stitch zig zag at a fairly narrow width.
Begin satin on one side of the center line of the mark. Slowly stitch down that side until you get to the end. STOP. Widen your satin stitch to the max. sew about 1/8" and stop with the needle down on the opposite side to your first line of stitching. Turn the fabric, narrow the stitch to match original satin stitch. Sew slowly down the other side of the center mark. STOP, lengthen the stitch, sew 1/8" then do a couple back stitches.
That's one way. Another older way is to sew 2 or tree straight stitch lines around the center line. Remove then use a hand rendered button hole stitch after you cut the hole.
Oct 27, 2013 | Husqvarna Sewing Machines
Husqvarna lily bobbin tension issues
Not sure if I can help, but it may have to do with the heavy thread as well as the fabric and needle combination. If the fabric is thick or tightly woven, be sure to use a brand new sharp needle. (If the fabric is tightly woven (like Batik), a thicker thread may present a problem.) In your case, if using a heavier thread, perhaps a top-stitch needle would be beneficial since it has a bigger scarf to protect the thread. With the heavier thread in the top, the top tension will need to loosened. BUT, if you loaded the heavier thread in the bobbin, the bobbin tension will need to be adjusted to accommodate the thread thickness. However, remember that if you adjust the bobbin tension for this project, you will most likely need to readjust it for the next project using different materials.
FWIW, if the machine still works fine with regular fabric and thread, then you'll know that the issues revolve around the current project.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 11, 2017 | Husqvarna Sewing Machines
I cannot get my sewing machine stitch the different stitches. I've followed all the instructions in the manual and all I get are straight stitches. I want to get a zig zag. Sometimes it looks like it did...
When you select a pattern does the needle move back and forth? do you make sure the stitch width lever is on straight stitch then select your pattern then select the widest stitch width? if when you select a zig zag stitch the needle does not move from side to side then you need to look in the top at the finger that goes round the cam.
Nov 04, 2009 | Singer 2732 Mechanical Sewing Machine
Needle position
First, select straight stitch on your pattern selector. Check your zigzag setting to see that it is on zero.If this doesn't help, push the needle bar to the left and see if it will move. It's possible the assembly is seized and won't move the way it is supposed to.
Next, try the widest zigzag stitch. If you only get a straight stitch it is time for a service.
sewman7
Jun 08, 2008 | Husqvarna Lily 540 and 550
Sewing Machines Logo
14 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
