Question about Toro Lawn Mower With Toro Power Tools
Turn the key for electric start,nothing happens
* fuse is OK
* installed new battery(charged for 48 hours)
* checked battery with voltmeter-measured 12 volts.
* have a toro 21 inch model 200039
* never used electic start--had mower for 9-yrs
* mower starts by pulling
  • 41 Answers
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
Posted on May 19, 2009
I have a 2007 Vmax 175 HPDI motor will not do anything when I turn the key the battery has 13.25% charged but I doesn't even click nothing can you tell me what's wrong I checked the fuses all OK
It's a electrical problem as when you turn the key nothing happens so first thing is get a multimeter and check the starter motor has power when you go to start the engine , check both terminals to and from the battery good luck colin
Jun 23, 2017 | Cars & Trucks
Will not crank over to start and nothing electrical works. Just installed a new battery. What can cause this problem? It was working fine when parked 3 weeks ago.
Test the battery with a voltmeter, if good, check connection to battery. Has to have a real good ground.
Mar 15, 2016 | ATVs
2006 jeep liberty turn switch on and have power.starter and battery gd but wont turn over wont even click
the tests are all easy,
check fuses first, on all electric fails, starter ,charge and EFI are all electric systems.
super easy.
  1. jumper cable cranked with donor running car work?
  2. yes, battery is dead, or only discharged, charge it work?
  3. yes jumps but charge fails, bingo battery toast.
  4. so the jumper fails. in #1 , all that is a bad starting system. (not a part, the system)
  5. clean battery lugs. check fuses, and then hot wire the starter solenoid lug (dinky lug ,not huge one) (in park and wheels chocked keys off)
  6. ok that fails the starter is bad.
  7. ok that works. so the KEY line is dead. try starting in neutral yet?> bingo works, bad PRNDL switch on tranny side.
  8. the KEY line can be interrupted with some alarms, on a jeep it has Immobilizer that cuts fuel not cranking. so.... PRNDL switch bad or the key switch is self .
  9. Using any voltmeter to do the checks is a WIN. 12.6vdc is a charged battery is yours 12.6v rested/???????????
Sep 17, 2014 | 2006 Jeep Liberty
Suziki Boulevard C90 wont start, when hitting the ignition nothing happens, no power, no light, nothing are on, it's never put the ignition on.
ASSUMMING THE BIKE IS 12 VOLTS WITH A NEGATIVE GROUND;
1. with a voltmeter check across the battery terminals and see that it has about 12-12.6 volts. If it does not then charge or replace the battery first.
2. Check the fuses; most bikes have a main fuse coming off of the battery or in the fuse box.
3. If the battery and fuses appears ok, check for loose or corroded terminals. Also look for connectors and wires that are corroded and/or have a melted look.
4. If everything before this checks out ok, check for 12 power at the back of the ignition switch.
5. At this point it is best that you have a wiring diagram to determine which wires carry power away from the ignition switch. Turn the ignition switch on and continue to track the power wires to where ever they go. When the ignition switch is turned on it should have some wires measuring 12 volts coming off of the switch or the switch is bad. Continue to track wires until they reach there source or a point that no longer has 12 volts and that will be the problem area.
Apr 13, 2014 | 2005 Suzuki Boulevard C90
Hi its me again. 2005 Dodge neon sxt. Auto tranny, put key in, turned it, started to crank for split second, all electrical went completely dead, no dome light, no head light, no dash light. battery was...
Ok, even if the battery is new, get a voltmeter and measure the battery, if its below 12v, thats the problem. That way you completely eliminate all these factors without a doubt. Also check negative wire from battery to the ground box and connections. It sounds more like a corroded terminal.
Mar 28, 2013 | 2005 Dodge Neon SXT
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
Nissan Altama Starter Relay electrical problems or a fuse?
Or the battery cables ! Do you know how to use a voltmeter ?
Starter Voltage Drop
Do you know how to do basic automotive electrical testing ?
How to voltage drop test starter motor circuit
Electric Testing Techniques You Need to Know Here is a place to view wiring diagrams ! http://www.bbbind.com/free_tsb.html
Apr 08, 2017 | 2004 Nissan Altima
2005 Sedona wont start, wont take a jump. Radio works and lights come on but wont turn over. Friend said to follow the positive battery cable to its end and id find the starter. cant find it. looked here...
OK, even if you find the starter, you'll have to find a way of testing it.
Starter Testing Starting System Voltage Drop Tests NOTE: The battery must be in good condition and fully charged prior to performing this test.
There are three area of the starter motor circuits that voltage drop test can be performed on. These include:
  • The starter feed circuit
  • The starter ground circuit
  • The starter solenoid.
Starter Feed Circuit
  1. Disable the fuel system by removing the fuel pump fuse or the fuel pump relay.
  2. Verify that the vehicle will not start.
  3. Connect the positive lead of a voltmeter to the positive terminal of the battery.
  4. Connect the negative lead of a voltmeter to the starter B+ terminal.
  5. Turn the ignition key to the START position and note the voltage displayed on the voltmeter.
    • Ideally, there should be no more than 0.1 volt drop for each connection displayed on the voltmeter. No voltage should be consumed by the vehicle wiring
      1. If the battery cable connects directly to the starter motor there should be no more than a 0.2 volt drop measured
      2. If the vehicle uses a starter solenoid between the battery and the starter motor terminal there should be no more than 0.4 volt displayed on the voltmeter
Starter Ground Circuit
  3. Connect the positive lead of the voltmeter to the case of the starter motor.
  4. Connect the negative lead of the voltmeter to the negative terminal of the battery.
    • Starter Solenoid
  6. Disable the fuel system by removing the fuel pump fuse or the fuel pump relay.
  7. Verify that the vehicle will not start.
  8. Connect the positive lead of the voltmeter to the case starter B+ terminal.
  9. Connect the negative lead of the voltmeter to the lug (the starter M terminal) that connects the starter solenoid to the starter motor.
  10. Turn the ignition key to the START position and note the voltage displayed on the voltmeter.
    • Ideally, there should be no more than 0.2 volt drop across the starter solenoid displayed on the voltmeter.
In general, there should be no more than a 1.0 volt drop throughout the entire starter motor feed and ground circuit. Any voltage drops measured in either the feed or ground circuits after connections have been cleaned will require replacement of the affected battery cable. Typically, any voltage drops measured in the solenoid are repaired by replacing the starter motor.
Starter Relay Removal & Installation Engine Compartment Relay Box kia-02-00-8057.gif
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Record the radio anti theft code data.
  3. Remove or disconnect the following:
    Negative battery cable On 2002-05 vehicles, shift cable Starter motor electrical connectors On 2002-05 vehicles, starter heat shield Starter motor
    Fig. Starter motor mounting-3.5L Engine
To install:
  1. Install or connect the following:
    Starter motor. Tighten the bolts to 20-24 ft. lbs. (27-33 Nm). On 2002-05 vehicles, starter heat shield Starter motor electrical connectors. Tighten the battery terminal nut to 106-141 inch lbs. (12-16 Nm). On 2002-05 vehicles, shift cable Negative battery cable Reprogram the radio anti theft codes
Oct 18, 2010 | 2005 Kia Sedona
Bike wont start. Solenoid clicks when electric start is pressed, but wont start.
When I had my VL 125 i got this problem after a very cold winter, I jumped the bike and ended up splitting the second ignition coil which fed back into and blew the DCI unit, wasn't cheap to have repaired but cheaper than new.
Firstly upgrade your plugs to iridium ones, they never let me down.
Secondly trickle charge your battery for 24-48 hours
Thirdly if still the same try bump starting bike with a good run up in 2nd gear as it may be a stuck starter motor.
The starter motors on these are known for their issues and again ain't cheap for new but if you know a good engineer, there are some ways of modding other starter motors to use as a replacement.
Jun 05, 2010 | 2003 Suzuki VL 125 Intruder LC
Where is the fuse for Craftsman 17.5 HP 42 Riding Mower
I'm not sure the solenoid/relay would even energize at 10 volts (so you may not hear the clidking).
The battery is essentially dead at 10 volts -- try charging again for 4 hours or so, and then measure the voltage.
If it's not up near 12 volts, you have a dead cell and need a new battery.
May 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro Lawn Mower With Toro Power Tools Logo
574 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
