Question about Craftsman 38cc 16" Gas Chain Saw
Mix oil ratio
What is the correct ratio for mixing the fuel for this saw please?
SOURCE: Kolher 17hp motor blowing oil/gas mix out of breather tube
I had the same problem! I found that the needle valve in the carb was not shutting off the fuel flow when not running. Either replace needle valve or put a shut off valve in the fule line. Should take care of the problem
Posted on Apr 28, 2009
  • 63 Answers
SOURCE: oil gas mix
50:1 50 parts petrol to 1 part oil
Posted on Jul 24, 2010
rycgl
  • 1545 Answers
SOURCE: what is the gas to oil mix ratio?
40:1....3.2 ounces of oil in 1 gallon of gas (use synthetic oil)
Posted on Aug 20, 2010
#1 Taper
  • 1041 Answers
SOURCE: I wish to know the
Here is a Link to a free pdf download of a Fuel Ratio Chart:
www.rctek.com/pdf/fuel_to_oil_ratio_chart.pdf
I'd like to be able to tell you, but without the Model # of your machine, I'm unable to do so accurately. It should tell in your manual what the ratio is.
Good Luck!
Jim
Posted on Oct 10, 2010
Editor925
  • 285 Answers
SOURCE: looking for a parts, specs for a craftsman
25:1 fuel:oil ratio.
Posted on Feb 15, 2011
What is the fuel mix for 14 inch chain saw csp3314
it depends on the make but sthil now have a oil that is suitable for all mix ratios up to 50:1
you can start at 20:1 and run the engine
if the exhaust is very smoky , change it to 40:1 and again check the smoke
50: 1 is thinnest oil ration for all engines
The ratio is correct when you can just see smoke when at revs
you can always google and type in--- oil/fuel ratio for ( make ) chainsaw model csp3314---or possible look at the filler cap as the ratio is commonly printed in the plastic cap
Feb 26, 2017 | Garden
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
Fuel mix ratio for 141 husqvarna saw
Hi lindsaybryne...
50:1 Oil mix ratio
1 pint of 2 cycle oil to 6 gallons of gasoline.
Please take time to rate me
Aug 16, 2011 | Husqvarna Garden
On a gas chain saw, do you mix the gas
there is usually a fuel/oil ratio (i think yours is 50:1) you must buy the 2 cycle oil and mix it with gas at the ratio reccommended by the manufacture. the bottle may say 6 oz per 1 gallon = 50:1 So 1 bottle of 2 cycle oil for every gallon of gas. mix them in a proper fuel can. then let the cutting begin.
Mar 17, 2011 | Homelite ZR10926 16 Chain Saw
What is the oil to gas mixing ratio for a poulan SM 4018 Pro chain saw?
The ratio is 50:1 fuel to oil using fresh fuel and a modern synthetic saw oil available from home centers, hardware stores, and saw dealers. Be sure to mix in it's own container, and shake thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 10, 2010 | Poulan Garden
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the oil mixture for husqvarna chain model 235
50:1 fuel to oil ratio is correct for this saw. Be sure to use modern synthetic saw oil, not a petroleum product like outboard motor oil. Premix the fuel and oil in it's own can, and shake thoroughly just before filling the saw each time. With these modern fuel/oil ratios, serious engine damage can occur if not thoroughly mixed each time. Hope this helps!
Sep 05, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I need to know the proper gas oil mix for the 42cc engine
50:1 is the correct fuel to oil ratio. Be sure to use a modern synthetic oil made for chain saws, and premix the fuel and oil in it's own can-- shake the can thoroughly just before filling the saw each time. With the very lean fuel to oil ratios used today, it is important to keep the oil in suspension to prevent engine damage. Hope this helps!
Aug 05, 2010 | Homelite ZR10926 16" Chain Saw
Mcculloch 310 oil mix ratio
The proper gas/oil ratio is 50:1, that is 50 parts gas, to one part (2) cycle oil.
If you plan on leaving gas in the tank when not being used, I always recommend adding some gas stabilizer, such as Sta-bil, which makes starting the chain saw easier regardless of how long the fuel mix has been sitting in the tank or saw (up to 2 years according to Sta-bil label)
Hope you find this Very Helpful and best regards!
Sep 09, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Craftsman 38cc 16" Gas Chain Saw Logo
13 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
