Question about Magic Chef CER3725AA Electric Kitchen Range
Magic chef electric range model 38HK-6TXW
Just moved into home with this range. F6 keeps appearing and buzzer sounds. It stops buzzing when i push claer,but comes back on after a few minutes. Now the oven will not get hot. Help!!!
  • moneypit47 Oct 19, 2007
    fridgetech,
    You are the man!!! Thanks for the info.
    moneypit47
  • 473 Answers
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Posted on Oct 18, 2007
Buzzing noise ft
Warning buzzer. Unplug and try resetting system
Oct 05, 2013 | Magic Chef Chest Freezer MCCF5WBX
F-1 displays of magic chef gas stove and buzzer sounds
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Oct 06, 2011 | Magic Chef 31000 Gas Kitchen Range
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
Magic Chef Model 68HK-6TXW...temp on he electric range will not go above 250, no matter where it is set. Ane ideas on where to check or where to go from here? Thank you don
some ovens have a centigrade/ celcious (sp) and f. check the owners man. for that, to switch back to F.If that's not the case then it sounds like you are only getting 110 vac instead of 220 vac. check breaker, then wireing.
Nov 10, 2009 | Kitchen Ranges
My mom has a Magic Chef oven, model 5892VRV. It
You have 2 choices.
Replace the electronic control(clock).
Or, replace the range.(stove).
Sep 04, 2009 | Magic Chef Ovens
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
REPLACEMENT COST OF MAGIC CHEF ELECTRIC RANGE MODEL 6898XVB
you should be able to buy one for between 400 to 600 dollars new.i would check lowes or home depot to see what they have in stock.
Jan 13, 2009 | Magic Chef CES3760 Electric Kitchen Range
Magic Chef electric range model # 3888VRA
Sounds like the oven control needs to be replaced.
Sep 24, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef CER3725AA Electric Kitchen Range Logo
772 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
