Question about Braun 360° Complete 8985 Electric Shaver
Side cover loose
Braun series 8000.I believe this shaver is a model 8781. This number is on the bottom left side in the center section.The side cover on the left side is loose on top and still attached on the bottom of the shaver. Is there anyway I can fix it? Everything else works okay. Sincerely, Jim Conley
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
A small steel piece came out betwen the head and body of my 8000 series Braun razor - now the motor runs, but the blade doesn't move - can I fix this (I still have the part)?
The 'drive unit' appears to be broken. You will find this item for model 8985 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
To replace, you will need to open the shaver body. You will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out
Jun 15, 2010 | Braun 360° Complete 8985 Electric Shaver
Braun Drive Unit 7030244
To open the shaver, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
You will find a replacement drive unit for model 8585 at shaveroutlet.com. See link below
Apr 07, 2010 | Braun 8585 Electric Shaver
Problem with shaver
are you talking about springs under the center cutter bar between the foils? If so, you will need a new foil and cutter set. It is available at shaveroutlet.com with link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
Or maybe you refer to a spring that goes to one of the clips that hold the foil assembly to the pivoting swivel frame. If so, you will need the part linked below
Jan 14, 2010 | Braun 360° Complete 8985 Electric Shaver
I just need to know where I can get new batteries for my braun syncro 7505. The batteries don't have any markings telling the volts or milliamps. I would greatly appreciate it if someone could help me with...
Yes, these are NiMH AA 1.2V flat top batteries. Replacements can be found on some battery websites (like onlybatteries.com). I'd get the 2200mAh rated ones, as they'll hold a longer charge than the 1650mAh ones. You will need two of them (the shaver has a 2.4V motor). This works for most Braun shaver models from 6000 to 8000.
Aug 15, 2009 | Braun Syncro 7526 Electric Shaver
The razor head comes loose from the two arms.
The one piece motor drive which also contains the shaver head in the Braun wear out. They can be replaced by yourself or a shaver tech. A good place for parts, http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
May 27, 2009 | Braun Syncro 7526 Electric Shaver
I had a similar problem where one of the side covers popped off. I was able to reattach it, by carefully aligning the spring and pushing back into place. If you've lost the pin, you're out of luck. Braun does not make these kinds of parts available for user servicing, unfortunately.
However, the 7000 series models are all compatible with each other in terms of motor, battery, and razor head armature. You could try locating a moderately used example on the cheap (maybe less than $20) and then cannibalize it for the parts you need.
Do NOT send it off to Braun for servicing, as you will be charged much more than the shaver is worth. If it comes to that, you're better off just going with an 8000 series shaver.
Mar 11, 2009 | Braun Syncro 7526 Electric Shaver
Braun 8595 vibrates excessively and sometimes jams
I'm in the process of replacing the Braun 8000 Series Activator Motor Drive Unit in my shaver. The Motor Drive Unit is all one piece, cost $33.99 at http://shaveroutlet.com/.To disassemble remove the plastic cover on the bottom that covers the cord socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I used my fingernail to create a space big enough to insert the corner on a credit card in the center of a long side and gently removed the cover. Using a screwdriver could damage the plastic. The two sides then pop off. There are a total of four screws holding the body together. Remove the screws, the shaver splits into. Remove the Motor Drive Unit and replace with new unit. There is also a circuit board with the batteries below the Motor Drive Unit. Assembly is the reverse of above.
Nov 25, 2008 | Braun Activator 8595 Electric Shaver
I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
Jul 07, 2008 | Braun Syncro 7526 Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
138 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
