Question about Numark iDJ2 - DJ iPOD Mixer Docking Station
Defragmenting idj2 on my computer
My Idj2 takes about a minute to search from playlist to playlist will defragmenting help speed
  • 21 Answers
SOURCE: My IDJ2 is unstable
not sure what it can be, but if you used librarian before, be sure that you are running librarian 1.50 with fw 1.09(a). If you have created a library with 1,33, then you have to create the library again with the 1.50 version. Don't use USB powered drives. Mostly they overload the USB port, with al sorts of weird problems. If you have one of these, use an USB powered hub to remove the load of the IDJ2 port. You could test with an USB stick, for a few hours..
regards,
Jack.
Posted on Jan 27, 2009
SOURCE: when i connect ipod to idj2 it still shows up old library...
I have the same problem. But it's easy to fix. You must connect your ipod to a pc and then you must go to My computer>(select your ipod and open the folder) and then delete the folder -   .Library   - It's done!
Posted on Apr 22, 2009
SOURCE: Firmware update wont load!!!
I had a similar problem when loading firmware with Mac OSX 10.5.
You can solve it by downloading the firmware on Mac OSX 10.3 and then the firmware is recognised by the !DJ2!
Latest firmware from Numark with the demo mode is rubbish. Demo mode keeps kicking in with no warning. Had to revert to previous version and it works fine.
Posted on Jul 23, 2009
  • 20 Answers
SOURCE: how to download firmware and librarian files to my idj2
The current firmware available is version v1.13 which is located at http://www.numark.com/idj2 . It also has Librarian v1.5 included with it.
Download the firmware to your PC and then unzip it to your desktop where you can retrieve it easily.
Transfer the firmware file to the handy little 128mb thumb drive that came with the idj2. (I moved all of the files from the thumb drive on to my PC so the firmware file was the only file on my thumb drive to avoid any computer related confusion)
Making sure your idj2 is powered "OFF" insert the thumb drive containing firmware v1.13 into one of the rear USB ports. Make sure this is the only thing plugged into the idj2 at this time(no keyboard, ect)
Turn on the idj2 on. You will see a message that says the machine is checking the firmware.(I don't have the system in front of me right now but that is roughly what it says) It will take a few minutes and the system will update to the new firmware.
Posted on Sep 10, 2009
SOURCE: My Numark iDJ2 won't update it's firmware!
I've tried it with a PC, I've tried it with a Mac, I've tried it with two different memory drives, and nothing will get it to update. Numark has a quality problem they need to address soon.
Posted on Sep 27, 2009
I want delete songs from idj2 pls help
There are no songs on the IDJ2
Only on your Harddrive / USb stick or Ipod.
If you want to play songs via the IDJ2, you need the librarian software for using the IDJ2 in combination with you songs.
Dec 02, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
My IDJ2 is not installing everything from my IPOD. I have checked my ipod and everything is on there however the IDJ2 is not showing up all my songs. Every playlist is missing songs and they are not...
it maybe due to protected files. some songs (files) are classified protected.. this very frustrating problem is the birth child of .... you guessed it ...apple. eg i have 2250 files on my ipod but can only play around 1900 on the idj2. i hope this helps
Dec 18, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
I just got an idj2. I downloaded the firmware. I went through the library process, though I'm not sure what that really did other than take a ton of time. I hooked my ipod touch (16 gig) to the idj2 and it...
Dan... I hate to be the bearer of bad news...
Located at http://www.numark.com/idj2 there is a link called iPod compatibility matrix v1.6 this link tells you which versions of the iPod work great with the idj2 and which versions of the iPod make you want to pick up your idj2 and smash it against a brick wall. Sadly, the iPod Touch falls into the "smash" catagory.
Generation 1 iPod Touch devices can only be used in "DIRECT MODE ONLY" which means you can use them like a cd player or as a music source on 1 channel of the mixer of the idj2.
Both Generation 1 and Generation 2 iPod Touch devices are not supported to be used with the idj2 in "MASS STORAGE MODE".
Jun 10, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
How to download firmware and librarian files to my idj2
Jun 06, 2009 | Numark iDJ2 Docking Station for Apple iPod...
How do I get my keyboard to work on the idj2? Keyboard will not continue to work. Have to unplug and replug every couple minutes to get it to work
1. I would suggest rebooting the device first.
2. If the problem persists try a different USB keyboard.
3. I'm assuming you have installed the Librarian software on you PC and formated you mp3 memory component to it already, if you haven't done it, do it, that is the primary component of the search engine feature of the idj2.
4. If the keyboard is still flaky try installing the firmware version 1.13 if you don't have it already.
5. If the problem is still there I would be concerned with calling Numark and getting a replacement unit ASAP.
Jun 01, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Still asks me to download librian
The idj2 doesn;t search off your ipod. you have to put libraries together with the librarian tool.
Here is a manual for your idj2 it's clear and will tell you how to import a library to your computer for search and play.
send me your email and I will send you a manual i downloaded steveb661@yahoo.com
May 18, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Library questions
Librarian 1.50 / IDj2 fimware 1.09
Read the other Q & A's, about IDJ2
Regards,
Jack
Jan 29, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Uploading problem
Some things you have to do yourself... It only takes some work to get it right.
For using ipods or harddrives/USB sticks with the IDj2, your best off with creating Numark libraries. This makes the IDj2 quicker when searching/loading tracks.
This can be done on your Mac or PC with
librarian 1.50/IDJ2 1.09(a)firmware combination. If you havent updated your IDJ2 yet, do so. It's the most recent verion, and fixes most problems...
Files can be found on www.numark.com/idj2. Look around in this page. There is also explained how to update with a FAT formatted USB stick.
If you have created a library before, Itunes won't update this library, cause it's made by Numark. Itunes and Numark use both a different database.
If you run Librarian, it will still see the Ipod playlists, and add them accordingly in your Numark database, and can be recalled in the IDJ2.
If you have created libraries with Librarian 1.33 or on the IDJ2 with firmware before 1.09. You have to remove the whole libary, and recreate one with Librarian 1.50.
Mostly there is a directory on the device called " .library ". You can throw this away, and recreate a new library.
Good luck and happy DJ-ing.
regards,
Jack.
Numark iDJ2 - DJ iPOD Mixer Docking Station  Logo
24 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
