Not Starting up
My Philips Freevents PC came up with the dreaded blue screen then shut down.It will not boot up anymore.when turned on I hear the HD starting but a few seconds later there is a click and the 'busy' light goes off and nothing more can be done.desperatly need to get it going again. Cheers. Jeff Yates
  • Jeff Yates
    Jeff Yates May 19, 2009
    Thanks alot.I'll try this after work tomorrow and let you know.
    Using borrowed laptop at mo and it's soooo sloooow.
    Cheers again
    Jeff
  • Jeff Yates
    Jeff Yates May 25, 2009
    Hi there.
    Finally got chance to try your solution.Unfortunatly didn't help.
    The PC is a philips freevents lx3000 and is quite small(unlike tower PC's). 280mm x 240mm x 45mm
    The motherbord doesn't appear to have a button battery as expected,Had to remove the dvd,But found RAM and cleaned as suggested. Also thought about removing HD and fitting to old PC to try and recover contents but it plugs directly into the motherboard and connections are different to other PC's i've had.
    Also the click after booting appears to come from the HD itself.
    Any other suggestions I can try.
    Jeff
    Problem Solver:
  • 11 Answers
In my experiences its (the blue screen o' deth)related to one of several things,
A, bios, the battery is running low and cant maintain functionality.
B, a stick of ram is bad(it just happens sometimes)
C,weak or over taxed power supply or lastly
the "BAD" harddrive(20's and 40's are bad for this)
1st try to remove the closest ram bank to the processor then try to boot, if nothing, power down and swap the removed bank with the current one and try again to boot up, if nothing find the button cell bat on the Mother board and pop it out by releasing the tab and check is power level(should say on the batt if its dead geta new one and put it in and try to boot up as far as the power supply goes< im not going to say you should test it your self. if you suspect it youll need to take it to a coputer shop, but I will say that if you use usb's as apower out to charge you cell and run neat lights and so on you will snuff out you power supp.
it sound like your HD is fine being that it makes noise at boot(its trying)
Posted on May 19, 2009
  • 4,806 Answers
Hi Jeff.
Take the side panel off the computer tower, locate the motherboard battery and take it out for 10 mins, (remove the power cord from the back before you open the PC up) while the battery is out take the ram (memory) out. Get a clean, dry, soft paintbrush and clean the brass contacts on the memory also clean the dust (if any) from where the memory slots into. Once done reseat the memory and make sure its clipped into place nice and tight. By now it should be time to put back the motherboard battery and restart the machine, if it boots up you will have to reset the time and date.
Please post back if you have any difficulties.
Good luck and thanks for using FixYa!!
Does not start up. tried f8 and f12 but always goes to the dreaded blue screen that begins with "a problem has been detected and windows has been shut down to prevent damage... etc"
have you pressed F8..as you start up your lappy.......if not try that..because you might not be getting in before your boot up in time..
Regards Tony
Mar 31, 2011 | Dell Inspiron 1525 Notebook
How do i tune in a 3 year old philips hd flat screen tv it is 3 years old bought from a friend.
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
May 08, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
Dell Inspiron Desktop PC won't start up
Hit FN at boot then let me know what it does
Jan 14, 2010 | Dell Inspiron 530 Desktop Computer
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I...
Try draining the flea power first
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
check if it will boot to windows, if not, there is a problem with your windows OS, try using startup repair. Hope this helps
Dec 11, 2009 | Acer Aspire One AOA150-1570 Notebook PC
I need to obtain a free down load of the instruction manual for a philips freevents lx2000 mini pc
Hi friend, please follow the link provided below just click on it or copy and paste in your address bar.
http://www.user-guides.co.uk/download/instruction/instructionmanual/instruction-manual-philips-freevents-lx2000-mini-pc.html
Please get your manual from here.
I hope this will help you. Plz vote Thanks.
Sep 24, 2009 | Philips Televison & Video
Toshiba cd/dvdw sd-r5372 crashing my pc (blue screen)
boot your pc on safe mode and check all the drivers .
What OS are you on ? win7 or win 10
Jul 06, 2017 | Toshiba SD-R5372V (SDR5372VBK) DVD RW Dual...
My bios isn't detecting my hd
most probably there's no other way you can retrieve you file
Dec 15, 2008 | Acer TravelMate 4010 Notebook
Toshiba/Philips screen flicker
no what is your settin in destop set at 1024x768 60 hertz only > ?
Jan 21, 2008 | Computers & Internet
Computers & Internet Logo
272 people viewed this question
David Payne
David Payne
