Question about Dishwashers
Hotpoint fdl570g The dispencer has stopped working so tablets are not dropped into the machine during the wash cycle. I have ordered a replacement unit. In the meantime I tried a wash with the tablet in the cutlery basket. Although the tablet disolved some cups on the top rack came out dirty. Can I just put the tab on the bottom before starting the dishwasher or will the tablet just disolve on the first rinse cycle? Thanks Mike
  • 641 Answers
SOURCE: ZANUSSI 695 Integrated Dishwasher
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
Posted on May 26, 2006
  • 10865 Answers
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Posted on Jan 28, 2009
  • 67 Answers
SOURCE: I have had my dishwasher for 3 years. In the past
I would say you are not getting any water flow since the water dissolves the tablet.
When starting it listen for the water valve opening and open door and see if there is any water.
If not it is probably the solenoid or a defective or blocked water valve which is not opening.
Posted on May 15, 2009
  • 52 Answers
SOURCE: Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Posted on Jul 26, 2009
  • 999 Answers
SOURCE: Detergent left in dispenser cup
You either do not have enough water getting itno the machine or it is not hot enough. 5 years old so I would suspect a plugged screen on the fill valve.
Posted on Dec 11, 2009
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
Nov 20, 2014 | Hotpoint Washing Machines
The washing machine is stopping half way through any normal cycle, seems unable to spin then stops. the spin is working on a rinse cycle
Possible that the suspect is the main program controller unit. You will need to check the voltage to the motor during the wash and spin cycle.
If there is no voltage then the controller can be faulty.
Feb 05, 2011 | Zanussi Washing Machines
Kenmore front Loader washer leaking from bottom
I want you to run an empty load, pour 3-4 cups of white vinager into the soap dispencer, this will flush out detergent buildup, it sounds like the unit has a buildup of soap and is oversudsing, the vinager wash will stop it from happening, if this stops the problem cut the amount of soap you are using in 1/2. If it does not let me know, good luck
Jun 07, 2010 | Kenmore 43142 Front Load Washer
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Kitchen aid washing machine, stopped during cycle wont drain...
if this is a top load unit your lid switch has failed , easy and cheap fix.
get your model number under the lid of the unit and go to sears parts for easy ordering. let me know if I can help more.
Jun 11, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Works on hot not cold cycle
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jun 10, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Keeps filling during wash cycle
If the machine des not stop filling and cycle hang in position, then it is a faulty water level switch.
If the machine does not stop filling , and the cycle goes on, then test that the inlet valve is not stuck in open position, if the inlet valve is OK, replace the timer control assembly.
Mar 07, 2009 | Hotpoint Ultima WD72 Front Load...
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
