Question about Canon PowerShot A85 Digital Camera
The code doesn't show up every time, but it's getting more and more often and nothing i can do makes it go away.
Taking it apart myself is not an option. I'm just not that handy. :)
  • 1 more comment
  • hera905 Oct 19, 2007
    the lens seems to be working...until that code shows up. then nothing works.
  • Anonymous Nov 03, 2007
    I have never had this problem until today. but E18 flashes on the screen and won't go away.
  • noidiots Nov 04, 2007
    Mine just started showing E18 today too! I also haven't been able to transfer photos from my camera to my computer for the past couple of weeks. Tonight I tried using a new USB cable to see if that might have been the problem and my camera started going nuts -- beeping, not showing anything but black on the screen, sometimes showing E18 on the screen and leaving the lens stuck in zoom. Are these cameras programmed to go bad after three years? What is the deal?
  • Canon Master
  • 4,738 Answers
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Posted on Nov 16, 2007
    Problem Solver:
  • 30 Answers
First tell me at this problem are your camera's lens woring properly or not
Posted on Oct 19, 2007
My camera was dropped and now when i turn it on it beeps and then the screen goes black and says e18. i would like to take it apart since i have nothing to lose. do you have anything that shows how to do...
E18 error refers to a lens error .Try checking if any dust got on the lens barrel if not check with the Canon dealer for a replacement as this is might be a factory fault
Mar 31, 2011 | Canon PowerShot A400 Digital Camera
The right side of the screen does not show a picture but still works to the touch. Is there a way to get the entire screen to work?
You need to check to make sure the lcd cable is secure by taking apart the lcd casing. Most laptops are all the same, just carefully examine around the lcd for the "hidden" screws and carefully take it apart. If the cable is nice and secure and the video issue doesn't go away then it's safe to say the lcd is on it's way out :(
Replacing them is cheap though! Just match the part number on the back of the lcd to the new one you buy on ebay. Swap it out and you're good to go ;)
Nov 12, 2010 | Computers & Internet
Canon PowerShot S2 IS camera showing code E18
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jan 20, 2010 | Canon PowerShot S2 IS Digital Camera
Fault code e18
Camera lens must have taken an impact, Because that error code means zoom lens error Have to unjam lens. Has to be done by a repair shop/person. A lot of labor to take apart, TC
Aug 31, 2009 | Canon PowerShot A70 Digital Camera
Received the error code from Canon Power Shot
Just Google E18 and you will find all kinds of advice on this long standing problem
Mar 08, 2009 | Canon Cameras
Quit working only beeps
i took my camera apart,and cleaned all contacts including battery posts and contacts for battery in camera. when removing the flexible ribbons take note that some have 2 wedges on either side of the connecters, which must be gently prised away from the conection in order to free the ribbon. the lcd screen (if i remember correctely) has a black tab running the length of the connecter, and this gets prised up to free the lcd screen--FOR CLEANING, I RUBBED EACH CONNECTION WITH A PINK PEARL PENCIL TYPE ERASER. CAMERA NOW WORKS GOODY GOODY.
Dec 19, 2008 | Samsung Digimax D53 Digital Camera
Canon powershot sd400 error code E18
Yes !! I wacked it a couple of times on a hard surface and it started working again after I dropped it and got the dreaded E18 error mesage in the middle of a Jewelry shoot. wm
Oct 14, 2008 | Canon PowerShot A80 Digital Camera
E18 pops up
An E18 error refers to a problem with the lens. Generally you receive this error if the lens is stuck, which often happens if you drop your camera while the lens is extended or if something like sand or dirt gets inside the lens barrel/gears. Your situation, however, sounds different since the lens seems to extend before giving the E18 error.
If the lens is fully extending before giving the E18 error, you most likely have a problem with the lens sensor located around the O-ring inside your lens barrel... either the sensor itself is damaged or the little plastic piece on the O-Ring that triggers the sensor is broken. If that's the case, there is nothing you can do yourself unless you feel like taking apart the entire camera and finding a replacement piece.
If the lens only comes out a little bit and is not fully extending before giving the E18 error, it sounds like something is making your lens get stuck. If you've recently been to the beach or a park where there is sand, try using a can of compressed air and blow it into the little gaps in the lens barrel... you may be able to blow the sand/dirt out, solving your problem. If the air doesn't work and you feel comfortable taking apart your camera, you can get to the gearbox and manually retract the lens by following my instructions below. Otherwise, I'd suggest a repair shop.
WARNING: TAKING APART YOUR CAMERA VOIDS THE WARRANTY AND CAN BE DANGEROUS! The capacitor that charges the flash can still hold enough voltage to give you a massive shock even when the battery has been removed for some time. Please only attempt to disassemble the camera if you feel comfortable doing so. I accept no liability for anything that happens should you follow my instructions below.
In order to open the camera you will need to remove six screws on the outer casing (2 where the wriststrap ties on, 2 on the opposite side, and 2 on the bottom). After unscrewing all 6 screws, pull the back and front casings off from the bottom out, as there is a clip-hinge on the top next to the shutter button that needs to disengage before you can fully remove the casing. Once the casing is removed, there is one screw holding in the flash apparatus, on the side. Remove it and carefully bend back the metal cage around the flash apparatus and pull it up. The flash will still be attached to the camera with a pair of wires (yellow and black) and a ribbon cable... leave those in place. Please be CAREFUL when handling the flash because the capacitor (the big black thing under the flash) can hold enough voltage to give you a severe shock even with the battery removed. Underneath where the flash was you will see a multi-tiered black piece of plastic... this is the gearbox cover. Remove the three screws from the cover and carefully lift the cover off the gearbox. Inside will be a motor shaft and 4 gears (2 white, 2 black). Remove the BIG black gear closest to the lens. Then temporarily replace the gearbox cover. With the big black gear removed, the lens should freely glide in and out if you push or pull on it. Do this several times in order to clean out any gunk that may have gotten into the grooves of the lens barrel. Then, open up the gearbox, replace the black gear, and screw the gearbox cover back on. Replace the flash into the metal cage and screw it back in. Finally, put the metal outer casing back on the camera and, before screwing it in, try to turn it on. Hopefully it will work again and you can screw everything back in. If not, your problem will require significantly more disassembly.
Apr 02, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Hi, I have a Canon IXUS 40 digital camera - My lens suddenly does not want to close and show me an E18 error code on screen - what is the problem?
Hey there johans, the E18 error code indicates there is a problem with your lens unit or lens cover. It was probably the result of an impact of some sort, or you may have something such as sand or dirt jammed in the device. If you cant see anything to clear and clean away, try turning off the camera and restarting. If this doesn't reset it and allow it to function properly, then you will need to bring it in for service.
Mar 31, 2008 | Cameras
Click here for help on repairing e18 error
good luck my friend!
Hope you will save 150$ for the repair..
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot A85 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
