Question about Sony Televison & Video
Sony rm s609
The buttons from cd till disk skip don't work anymore. Is there an easy way to open te remote control and clean it inside without damaging it? Thanks a lot
4 Suggested Answers
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Posted on Jan 02, 2011
SOURCE: Hello, my Sony remote control
I had same issue - took it apart on the off chance it may be dirty inside. Low and behold sticky substance - my guess juice (or beer!) on pcb sensors - gave it a quick clean and drying out, good as new.
SOURCE: Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Posted on Nov 02, 2013
Sony rm ss251
As all other buttons works properly except Volum Dn, the problem is with the remote control itself. Clean the remote control and check. To clean it, you have to open the remote control. If it too doesn't help you, buy one original remote control from the authorized service center for Sony. No universal remote control will go properly with Sony TVs. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Sony Televison & Video
How do you Open Sony rm-yd059
SONY RM-YD059 remote is easier to disassemble then other models. Slide battery cover open 1 inch or half open. Using a plastic toothpick or similar device pop cover using the groove. There are three sliding locks on each side. You will now see six screws holding halves together - remove. There are six more clips holding remote together. Starting at the top working towards the bottom, there are three per side, location of clips at red and blue buttons, at between 4&7 and 6&9 rows, and finally at muting and jump buttons. Voila - Happy cleaning. Note: directional ring is keyed with thin and fat tabs, fat tabs are positioned towards the bottom.
Feb 04, 2013 | Sony RM-YD059 Remote Control 148947911
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
You are done.
Apr 01, 2012 | Sony Rm-yd035 Remote Control
How can i open my sony rm-ed009 remote control
Feb 11, 2010 | Sony Televison & Video
Cd skips at beginning of cds
the data on compact disks usually starts on the outside of the disks and spirals to the center. My guess is that the laser unit that reads the data is malfunctioning. It moves on a rail from the outside of the disk to the center. About all you can do if try to clean the laser unit or lens assembly. If you can get to the laser lens, blow it off with canned air. If you can not get directly inside, open the CD drawer and shoot the canned air into the machine through the drawer openings. I suggest that you open the CD drawer with the open button then unplug the machine. At that point the drawer should be open and you will have some access to blow off the CD reader.
good luck cleaning the CD reader!
Jan 28, 2010 | Sony CDP-CX300 CD Player
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Aug 24, 2009 | Televison & Video
How to open remote control Sony RM-Y181
There should be small screws (usually phillips head) at either the top, bottom or both ends of the back of the remote. Unscrew those and pry loose. If not, they will be under the batteries, inside the battery cover.
I assume that's what you mean by open?
:D
Aug 10, 2009 | Televison & Video
We have had our Sony 200 disc changer for about 7 years. Lately the disc are skipping. We took them all out and attempted to clean but did not see any dust or anything that would cause this. Also the...
Have you tried cleaning the lense?you can buy a special cd that you put in and this will clean your lense for you as they are quite sensitive and the slightest spec of dust could cause it not to work!hope this helps!
Dec 14, 2008 | Sony RM-U305A Remote Control
Cant control toshiba tv model ce19t11
it is one of these code you will have to try them all till you get the right one they are 059    060    019    014    052    075
1 turn on tv to be prog
2 on remote hold down set
3 whilst holding set button press and release power button
4 release set button
5 press tv button on controll
6 using key pad key in code
7 press enter button
8point remote at telly
9 press power button c if it works
if not work start again but use next code keep going till you get it to work try this site as well http;//esupport.sony.com
Oct 26, 2007 | Sony RM-V302 Remote Control
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
