Question about Samsung DMT300RFS Builtin Dishwasher
Samsung dw7933 low level water error
Dishwater starts but stops and does not drain
4 Suggested Answers
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Posted on Sep 21, 2010
SOURCE: Low water level error with
Do you hear the washer draining (into the sink drain) after it fills and should start washing? Check that nothing (sound deadener, etc.) is interferring with the drain valve lever arm.
Posted on Feb 08, 2011
spucketts
SOURCE: Samsung DMT300RFS dishwasher; low-level water error
A Samsung service tech showed me how to fix this one. You can take that float and the white box apart from the dishwasher and once opened, if its like mine, there will be gunk on the float and in the box at the line where it fills with water. This gunk floats in there and prevents the float from swinging and activating the switch. Just clean that gunk out with a toothbrush, I end up doing mine about once every four months, and it should work fine again. This tech said to prevent this, make sure the water is hot at the beginning of the cycle and pre-rinse the dishes-but this doesn't seem to work with mine.
Posted on Jul 25, 2012
My samsung dw7933 will no drain out all of the water and it makes a grinding noise. where can i find the error code?
It might not throw an error code. There is usually a filter and a drain. I have seen coins and hair pins etc get stuck in the pump and cause excessive wear. If you take the cover off the filter, get ready for some water to come out.
Oct 10, 2017 | Samsung Washing Machines
Tip
Error codes
Samsung Washer Fault Codes
4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
5E WATER DRAIN ERROR 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drainerror can be cleared by turning POWER SW OFF and back ON.
oE OVER-FLOW ERROR Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
UE UNBALANCE ERROR Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
HE WATER HEATER ERROR HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
1 E WATER PRESSURE SWITCH ERROR * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is aPRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
cE ABNORMAL WATER TEMPERATURE ERROR e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
11 E WATER LEAKAGE ERROR Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
tE THERMISTOR ERROR This error occurs when the Thermistor circuit is abnormal or a voltage of O.2v or below or, 4.5v and over is detected. This error can be cleared by POWER switch OFF.
3E MOTOR RESTRICTION ERROR Hall Sensor is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error isdisplayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
8E OVER CURRENT ERROR IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
on Apr 14, 2015 | Washing Machines
What causes a Low-level water error on the dishwasher. Samsung, DW7933 Series
perhaps if we knew the MAKE .information could be found
Jul 19, 2016 | Dishwashers
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
How do u fix a low water level error on a Samsung dw7933
Hello. The problem you're most likely having can be caused by a defective or clogged case sensor assembly located on the left, outside wall of the dishwasher. The part number for the case sensor is DD94-01006A. It is mounted to the bottom of the brake assembly, part number DD94-01005A. The case sensor sends a signal to the main board telling it how much water is entering the washer--if this part is defective, it must be replaced as it is not serviceable. The dishwasher must be pulled out at least halfway to access the parts. Be careful when removing the brake assembly and separating the 2 parts--take photos and/or make a diagram of how the parts fit and be careful when removing the wiring connectors. REMOVE POWER BEFORE WORKING!! If you are unsure or hesitant about any of this, call for service.
Aug 28, 2015 | Samsung DW7933LRASR New 24 Dishwasher
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Why My Samsung DW7933 Series Dishwasher starts a wash cycle then makes series of beeps and stops with Quick ligt flashing?
That indicates a drain error. You may have something hard caught into the impeller of the drain pump, or your might have a bad ECS sensor causing that (false) error code.
Feb 13, 2015 | Samsung Dishwashers
What could be the problem on my Samsung DMR57LFS dishwasher with an E9 error after the low-level sensor is cleaned but the error still exists?
This is an exhausting procedure you have described here. Have you checked the float in the low water reservoir is actually working.
Sep 15, 2014 | Dishwashers
I have a Samsung stainless steel tub dishwasher and only 2 months after we had it installed we had all sorts of issues with it. We were lucky it was under warranty and turned out parts needed to be changed - upgrades from Samsung that were not done i nthe store where we purchased the dishwasher.. You may want to check with Samsung with your Mode land Serial Number you never know, there might of been a recall. Good Luck!
Sep 15, 2014 | Samsung DMR57LFS Stainless Steel Builtin...
Samsung washing machine sw7oz1fw-yl start with errorr code E1
This is Water Pressure Switch Error.
A paragraph from the Guide :-
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 19, 2009 | Samsung Washing Machines
Samsung DMT300RFS Builtin Dishwasher Logo
1,562 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
