Question about Protron PLTV3250 32 in. LCD Television
Protron (PLTV 3250) loss of power
Was being used only as a monitor and working fine. Next attempt to power up the unit acted as if unit had no power. Checked power from wall through cord and all was ok.
  • jautry731 May 24, 2009
    I checked the fuse and it's fine.
  • jautry731 Jun 08, 2009
    Ok, I've replaced all capacitors on the low side of the power supply, successfully. I also inspected the entire board for "cold" solder joints, but still nothing.
  • 230 Answers
If the fuse is good it sounds like you may need to replace the capacitors in the power supply of the unit. It means the supply is likely not kick starting into oscillation. The most common cause for this is bad capacitors in the power supply.
The first capacitors to replace are the smaller ones on the primary side of the transformer they look like this typicly around 100v at about 22uF:
Protron (PLTV 3250) loss of power - 62737e9.jpg The next step is to look for any leaking capacitors and replace those, they normaly have bulged tops and have stuff leaking out of them somtimes, they look like this:
285dba1.jpg A good repairer will just replace all the electro's on the board to save a future repair.
The last step before testing your unit out is to resolder any dry/cracked solder joints they typicly look like thiProtron (PLTV 3250) loss of power - 01da546.jpgimg src="http://i.fixya.net/uploads/images/01da546.jpg" alt="01da546.jpg" class="h_mi" />
The above is a general guide for repairing a power supply in consumer electronic gear where there does not seem to be any smoked components and there is voltage getting to the main filter cap after the fuse. It's assumed that the reader has electronic background is competent in regard to safety, if this is not the case then the repairs should be carried out by a competent repairer. If you do however take on the repair I will not be held responsible for your safety it's at your own risk.
Hope this helps
Posted on May 25, 2009
  • 749 Answers
Hi, you need to change the FUSE from the plug.
Posted on May 23, 2009
My TV will not pwer on, I have replaced the ac power cord and made sure the switch was in the on position that is next to where the power cable gets plugged into the tv. The blue led lite in the front is...
This is common problem with the PLTV-3250, the power supply DC filter caps go bad, 5vdc standby transistor and diode shorted out.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Jul 12, 2010 | Protron PLTV-32 Television
Protron pltv 3250 power cord
It is the same power cord as used for your PC, NEMA5-15P to IEC C13.
This TV has known problem with power supply, so keep an eye on it.
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 18, 2010 | Protron PLTV3250 32 in. LCD Television
No power to my protron PLTV-3250.
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, coomon problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
Power supply; http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=hdgBTL6MJaKMNZLC1Ts&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCQQrQQwAA
May 16, 2010 | Protron PLTV3250 32 in. LCD Television
No power on my protron pltv-3250. Any advise? larry
May 13, 2010 | Protron PLTV-32 Television
No power on my protron pltv-3250. any advise? larry
Check the fuse, if it is blown, replace with exact same one. Try again, if it blows again, its a power supply problem for a repair shop.
Mar 22, 2010 | Protron PLTV-32 Television
I need to find a PLTV-32 Protron HDTV Power Supply 090-02180-I3. Do you know of any location?
Power supply board for Protron PLTV-32 is available is Shop Jimmy, click link to have price info.
Thanks.
Sep 18, 2009 | Protron PLTV-32 Television
Tv has no power - Protron PLTV 3250
Look at the othewr posts for Protron PLTV - 3250. You need a power supply.
Aug 16, 2009 | Protron PLTV3250 32 in. LCD Television
Connecting a Protron PLTV 3250 to a home theater system
Standard RCA cables are fine to connect both units. If home theater and tv has Component Video (Green-Red-Blue) connections, you can get better video result.
Sep 11, 2008 | Protron PLTV-32 Television
Protron PLTV-3250 won't power up
Probably same problem I have with my PLTV-3250. dead power board.. I still can't find anything affordable to get it fixed.. good luck..65d2d93.jpg
Mar 07, 2008 | Protron PLTV-32 Television
Protron PLTV3250 32 in. LCD Television Logo
76 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
