Question about Avaya Lucent Partner 616 Phone
Lucnet 18D my Display has NO ASA/DXD Card
I was trying to change the main greeting and I hit Itercom 891 and I got this message on my dispaly No ASA/DXD Card how do I get rid of it and get my date back the time on the phone is correct. This message comes up on both ext 10 & 11 but all other extensions are fine.
  • cherylisbell May 20, 2009
    So how do I remove this No ASD/DXD Card diplayed on my display?
Try rebooting the system. Because you tried to dial the ASA extension, it gave you that error. See if just rebooting the processor gets rid of it.
Posted on May 21, 2009
How do I record the Main Message people hear when they call my company?
Note: Voicemail may ask for mailbox and password. Please consult your owner's manual for the credentials.
To change Main Greeting messages, here are the following steps:
-Go into the Supervisor Options
- To Access Supervisor Options:
- From main menu, press 6 for Supervisor Menu
-Press 2 for Routing Box Administration
-Enter Box Number that you are changing / recording
(Main Day Greeting is box 800, Main Night greeting is box 801)
-It will repeat the number you entered and prompt you to press 1 if its correct
-Press 3 to Modify
-Press 1 for Greetings
-Press 2 to Record Greeting
-Press 1 to replay current greeting or Press 2 to record greeting
-Press * (star) for current greeting
-Record greeting.
Jul 17, 2014 | Comdial Dx-80 7260-00 Digital Executive...
I have recorded an outgoing message. However, at the end of the new outgoing message an old obsolete outgoing message starts to play. How do I get rid of the old outgoing message?
You will need to remove the old message. There SHOULD be prompts. IF NOT try going to a very quiet room and hit record but do not say or make noise and this will record silence over the old and new message. Then attempt to retry.
ALSO - look for a 'reset' button and remove all batteries if you have power outage back up batteries.
Unplug the phone - and try again.
Here are the instructions from the manual:
To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Best of it
Gary @ Fix Ya
Jul 20, 2011 | NorStar M7324 Telephone
Changing main voicemail message
This may be specific for my system, but hopefully it helps:
Connect to your voicemail (for us, we can either hit the voicemail button or dial 1650)
Once in, press #6, it will ask for a mailbox number, dial *9998, it will ask for a password (the default is 1234#)
Press 5 to modify messages.
Press 3 to record custom service menus.
It will ask you to pick which menu (1-100). Our day menu is 1, and night is 2. I'm guessing yours will be the same.
From this point, it becomes the same as recording a standard voicemail greeting. It will play the current greeting and you can press 1 to re-record it. Do so, and then press #. Press 2 to accept and you're done!
Dec 24, 2009 | Panasonic KX-T7630 Corded Phone
No date on phone.. it has a message of "no asa/dxd card" how can we get the date back on the phone?
You have to program a button on ext 10
by doing a command #111
Toggle button on and off to clear the message
Jul 29, 2009 | Lucent PARTNER18 Corded Phone
Getting rid of automatic transfer
you need to change the zero / timeout transfer for the auto attendant programming to go to a general mail box. do you have the manual?
Jul 06, 2009 | Lucent PARTNER18 Corded Phone
Cannot change Main Voice Mail Greeting
after dialing 72 you must first hit the instr key in the display than dial 001 or 002.
Apr 06, 2009 | NEC Dterm DTP 16D-1 Corded Phone
How do i record the main greeting on a comdial edge 120
I just went thru this.
Push the Voicemail button, hit # until it asks for mailbox #, then hit 70 for password. Wait for main menu, then hit 3 for options. Then hit 2 to record your greeting. Now the tricky part,,, I don't know if these are all programmed the same way, but it will ask for the number of the box you wish to change, ours is 800, then follow along.
good luck!
What I'm trying to find out is how you can import a prerecorded message (mp3) as your greeting.
Jan 07, 2009 | Comdial Lands Phones
Partner 18 - voice mail greeting
Hi Smr. I ran into the same problem. I found out that ASA means auto answer. My phone guy said its rarely used anymore becuase autoattendant does so much more. you get the message when you enable (or in my case) access anything that needs the card. I did it by accident by hitting intercom 891.
I found a thread that suggested a system reset that worked ... and (I confirmed ion page 4-55 of my manual) it doesn't erase any settings ...but it does disconnect any calles in progress.
In case you don't have the manual here's the procedure (which I just did minutes ago)
hit "feature", "00" , then "#728"
Sit tight about 10 seconds and all should go back to normal.
email me if you have uestions or need a copy of the manual.
danland@sbcglobal.net
Nov 16, 2007 | Lucent PARTNER18 Corded Phone
Lands Phones Logo
648 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Cabanaboyz
Cabanaboyz
Level 1 Expert
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
