Question about Hotpoint Ultima WF860 Front Load Washer
Flashing tap icon and h2o
Is not filling up with water but has been working and now not
flashing tap icon and h20
  • 90 Answers
Might be a kink in the hose. Turn off water disconnect from machine then make sure water comes out of hose when waterturned on.( Put into bucket or similar to test) If water is flowing ok then you need a new inlet valve.
Posted on May 20, 2009
My Indesit 7105 has flashing H20 lights, have checked but no blockages. It fills and drains fine, It wont agitate though, any ideas?
The machine does not fill with water or 'H20' flashes in the display.
The water inlet hose is kinked. • The water inlet hose is not connected to the water supply. • The water pressure is too low. • The water tap has not been turned on to allow water to flow into the machine. • There is no water supply to the house. • The inlet valve filter is blocked. • The START/PAUSE button has not been pressed.
Faulty pressure switch machine thinks there is no water in the machine.
Apr 01, 2017 | Indesit Washing Machines
Why is my indesit washing machine displaying H20 and not opening
• The water container must be emptied? The "Empty water container" indicator light flashes and the message appears "H2O" (see Maintenance).
Dado
Jun 29, 2015 | Indesit Washing Machines
My indesit washing machine is flashing H20 i dont know what is wrong
H20 means not filling with water properly.
Check hoses and that taps are fully turned on , make sure water pressure is o/k, no kinks in hoses
Oct 09, 2014 | Washing Machines
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
Could you please tell me what h2o means on my hotpoint aquarius washer
Hi
H20 on these washers is a filling problem.
What you need to do is make sure the water supply tap is turned on the hose at the back isnt kinked up.
Take the fill hose off and aim it into a bucket and make sure the water pressure is good.
If thats all ok then you will need a multimeter and test the coils on the water valve and if faulty the valve will need to be replaced.
Check them and see what you find.
But the H20 error code is a water filling problem.
Aug 04, 2013 | Hotpoint Ultima WF860 Front Load Washer
H20 keeps flashing
  • H20 - Not fillings. Check tap, hose and inlet valves
  • If you have proper water pressure the your water inlet valve on the machine is bad and needs replacing.
Dec 21, 2010 | Hotpoint Washing Machines
Set wash program ,wont start ,there is a tap on display plus it flashes up H2O
H20 means a water inlet problem.
Check the inlet pipe/s are not restricted or kinked.
Ensure that the pressure is adequate.
This cold weather has caused some washer hoses to freeze up.
Hope this helps.
Jan 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint aquarius washing machine wd 640 is showing the fault h2o
The code h20 indicates means (not filling)
check the tap/s, hoses, and water inlet valve/s.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint ultima wt940 washing machine,, which is displaying a tap symbol,, when it fills up at the start of the cycle,, h2o flashes on the screen,, then the machine stops. Any advice? Thanks.
H20 is indicating a problem with the water supply.
Check tap/s are turned on fully, no restriction in hose/s, and make sure that there is sufficient water pressure.
Another possibility is that the inlet valve/s are faulty inside the washer.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
203 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
