Question about Microsoft Fable 2 for Xbox 360
Legs not moving but i am
Dude...i was playing it for like 5 hours then turned it off for 1 hour and i turned it on and my guy's legs would not mov, but yet he would...i tried to turn it off, back on, going to new regions...help me please!!!!!
  • 31 Answers
This looks to be a game disk problem, if you've played for 5 hours straight the heat from your 360 can warp the disk or damage the magnetic strip and the slightest changes there can do a number of things. Keep trying but you will most likely have to get a new disk... Sorry
Posted on May 25, 2009
Why are my controls invisible?
dude it is a bug..or we call it glich..
Jun 05, 2015 | Mojang Minecraft - Pocket Edition for...
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
Hey,i got my 2nd hand xbox360 .i wan playing like for 5 hours then i closed for 2 hours then i play again within the 1 hour is freeze and i restart and i got the RROD
Either. a) Put a towel over the xbox and let it run for 5 hours. Then restart it.
Or b) call 1-800-4myxbox to get it shipped in and fixed
May 11, 2011 | Command & Conquer: Red Alert 3 Sealed for...
I charged my psp for atleast 5 hours.....but charge ended within 1 hour......what to do??
I'm just restating what you said here first...
You plugged in your psp for 5 hours.
You took it out.
You played it for 1 hour before it turned off...
If this is true, it seems that your battery just can't hold a charge. One solution would be to just buy a replacement battery, but you could try this...
Drain your psp completely. This means keeping it on until it turns off, then turn it on again, leave until off and so on. Just keep turning it on until it stays on for less than a minute.
Charge your battery overnight.
Hope this helps!!!
Oct 07, 2010 | Sony PlayStation Portable (PSP) Console
Skips time
If it is not a feature built in to the watch to save power when it needs winding, I would say it has a bad gear wheel inside.
I would go here, join, and ask in the Rolex Forum,
http://www.watchuseek.com
These guys are really knowledgeable.
Jun 15, 2010 | Rolex Daytona 116520 Wrist Watch
How do I get both 8 hours time and high setting on this crockpot?
I got it on high for 1 hour and then reset it to low for 7 more hours and everything appears to be fine. I suspect that this crock pot runs at a little higher temperature. The *low* setting seems as hot as my older crockpot on high...... With this crock pot - set the hours while turned off with the right button and then turn it on. You may have to play with it several times to get the proper heat setting. As I said, I could only keep on it *high* for 1 hour.
Nov 22, 2008 | CorningWare SC60 Slow Cooker
TV goes off while watching it. Model TRX 3079WHX-Xac
First thing I would do is go back to the dude that charged you $239.oo for a non repair and have him make good! Then see what happens. It, obviously, was not the transformer and his diagnosis was incorrect. Not right for you to pay for his mistake. U paid good money for a repair and all you got was the set back with a different transformer and same issue.
Mar 12, 2017 | Samsung DynaFlat TX-P3076WH 30" TV
Disc unreadable
Dude mine does the same thing
What I do is pop off the front cover
find a black gear under DVD drawer and with game loaded move gear all the way to the left which engages drawer disc positioning to proper place for a "read" if I leave my disk partially raised it will scratch the disk!!!
This is what works for me-{out of warranty}
Sep 03, 2008 | Microsoft Xbox 360 Console
Turns off between 1 hour and 5 hours
sounds defective, but try the Insignia help line, in case you've accidentally got it on a timer setting:  Call 877-467-4289
May 12, 2008 | Insignia LCDTV26 26 in. Television
Setting model number jr3060-59f
1. set mode to CHR with the bezel fully in.
2. pull bezel out 2 notches. This will set all (or most) hands to 12.
3.press A (top button) repeatedly until you get MIN in the left window
4.turn the bezel to move the min hand forward.
4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Microsoft Fable 2 for Xbox 360 Logo
130 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
