Question about Intermatic T10404R - Two 220 time clocks in raintight box
Low speed side wont trip to the off position, even with the tripper in place.
The timer wont trip to shut off the low. the one that controls the high speed works fine.
5 Suggested Answers
protek480
  • 1723 Answers
SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
  • 5603 Answers
SOURCE: tripper makes contact but fails to fully trip switch:
These often have wear problems. Look for wear on the trip clips.
Posted on Aug 24, 2009
  • 52 Answers
SOURCE: need timer trippers for model 3405 24 hour
Replacement parts at electricalexpeditors.com
Posted on Dec 30, 2009
SOURCE: Timer will not shut off
T40004R 100 amp control panel has one 240Volt T104M timer mechanism.
1) If this is new installation then timer is probably wired wrong.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
2) If timer worked before and stopped working, and timer dial is rotating and keeping good time, sounds like you need set of 156T1978A trippers.
3) Open following link for timer troubleshoot and trippers:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Posted on Jun 18, 2011
I have unscrewed my tier pointer by mistake to coincide with the current time on my T21004R timer. Now I cannot get into start and turn off where my on and off indicators are set. How do I correct thi
T21004R is single 240Volt T104M mechanism inside a 60 amp control panel.
The T100 series timer has stationary pointer that is supposed to be straight downward. Move pointer into downward position and apply bit of super glue to hold in place, or just remember where it should point.
Copy following links for instructions how to set and use the T104 timer.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
The T104 timer is rated for 40 amps, and is usually repairable, uses WG1573 replacement clock motor, and 156T1978A trippers. Trippers are made of softer metal and are designed to wear out before wearing down timer mechanism.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 20, 2012 | Intermatic T21004R- Pool-Spa Mechanical...
My timer works fine but I need to buy extra trip pins so that I can turn my waterfall off for three hours at a time. Where can I buy extra trip pins?
Timer is not identified.
Copy following links for intermatic timers, and trippers:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
Jul 16, 2012 | Hardware & Accessories
Intermatic T104 timer wont turn pump on,despite being tripped
If override lever snaps back and forth crisp, and turns pump ON-OFF, then timer switch is good.
Try installing new trippers. The trippers wear down and start to slip over the trip lever.
If pump does not turn on-off with override, look for loose wires at breaker or pump.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
Jun 06, 2012 | Hardware & Accessories
What is name of srew on timer dial that trip switch .
It's called a tripper.
Question posted under Paragon 4000 series timer that uses X2772 tripper.
Paragon is no longer making that timer or tripper.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
If different timer is needed, use Intermatic crossover to match timer number:
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Sep 01, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Apparently, the spring under the timer dial on my 4001 timer has been broken and the timer will no longer trip the trippers. Can this be fixed? It is a nearly-new unit and I like it.
Open following link for Paragon resources:
Individual parts are not sold except for X2772 tripper.
Move the manual override lever back and forth and see if load turns on-off.
Watch if on-and-off trippers are moving override lever back and forth, to see if problem is a worn tripper instead of broken spring.
Replacement 4001-00 timers are sold, even though Paragon is no longer making timers except defrost timers.
http://www.mdappliance.com/RBS-4001-00.html?mv_pc=00015
Replacement timer is Intermatic T101
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Jun 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
GE Indoor Outdoor Timer # 15306 the clock is working and the when the time for it to go on it goes on but when the time comes for it to shut off it does not trip the off switch. I then have to shut it down...
1) If analog dial keeps time, I can only guess that OFF tripper is not in position correctly, or tripper is worn or defective, or that manual override lever is defective. Trippers are made of softer metal so they wear down before other parts of timer.
http://waterheatertimer.org/images/GE%2015306%20Mechanical%20Outdoor%20Box%20Timer-24%20Hour.jpg
2) Buy Tork P47 trippers to replace GE 15306 trippers
http://waterheatertimer.org/Tork-timers-and-manuals.html#Trippers
3) Open following link for GE timer resources:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
4) 15306 is heavy-duty indoor-outdoor version of Tork 1800 series or 7200 series 120Volt analog timer that is sold online and at Home Depot under GE brand name.
http://waterheatertimer.org/images/Tork-1800-600.jpg
5) You can buy new timer at Home Depot and return defective one in new package.
6) The on and off trippers are attached to the analog dial.
Dial rotates as time passes.
Trippers make physical contact with the manual override lever. The ON tripper pushes lever one direction and the OFF tripper moves lever other direction.
The override lever rotates a cam located on back of timer that opens and closes electrical contacts.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | General Electric GE 56941 24-Hour Outdoor...
I get lights when I turn the switch to on but as the timer advances, it doesn't trip and turn the timer on
You posted under Intermatic T101 timer.
Add a comment if timer is different.
1) If this is new timer installation, it sounds like black wires on terminals 1 and 2 are reversed.
Other cause could be the ON-OFF trippers not positioned on timer dial
2) If this is old timer that worked before, then tripper pins could be worn down.
Buy new trippers for T101 at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Nov 17, 2010 | RTO Intermatic T101M Timer Mechanism Only...
My paragon timer4001-ov runs but will not trip on/ off trippers if this cannot be repaired what would be a good replacement for 120 volt supply
I don't see the 4001-ov in the Paragon spec sheet
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
To test the general condition of your Paragon timer, use the manual override.
If the manual override works perfectly, then you may need new tripper pins.
The Paragon 4000 series uses X2772 tripper pin.
Google search Paragon X2772 tripper turns up prices of $9 for a pair of trippers
A simple 120V replacement timer is the Intermatic T-101
For outdoor, use the T-101R 'R' for raintight
Lowes usually has the T-101 on the store shelf and they sell the T-101R online
http://www.lowes.com/pd_29405
http://www.aplussupply.com/intermatic/timer.htm
Oct 28, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
The Off tripper does not switch timer clock off
The pins trip a switch behind the dial, you can't see them. Don't worry they will trip the switch and turn and off. Just slide them on the edge of the time dial where you want to go on and off and tighten.
Jun 12, 2009 | TORK Digital Interval Timer Ssa100r-24
Automatic drying doesn't shut off
its the switch problem its got tripped internally so its not getting shut off.if the switch would have tripped to the opposite side that the dryer would have nit turned ON. so the switch needs to be opened the tripper needs to be replaced.easy job but very technical. thanks
Feb 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Intermatic T10404R - Two 220 time clocks in raintight box Logo
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
