Question about Zenith Audio Players & Recorders
Zenith z1261s stereo cd radio w/auto set digital tuning
3 Suggested Answers
oldnovii
  • 667 Answers
SOURCE: auto-set clock radio with digital
Hi masbarn - I could try and walk you through it but I've always believed it's better if someone has the manual with the pictures. The link below is for the T311. It supposedly is the same manual you need. If not let me know. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Jeff
Posted on Jul 31, 2008
SOURCE: Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
Posted on Mar 14, 2010
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
How to save FM radio settings in JVC car stereo
Try this, tune to the desired radio station and holdpress the station number ( 1-6) for a while, it should blink twice to confirm its storage.
Ekamave
Jan 12, 2011 | JVC AM FM CD DET FACE CAR STEREO
How do you set the time and alarm on a Zenith Z1261S??
body{padding: 10px;}#Post p {margin: 0px; padding: 0px;}#Post ul{padding: 0px;margin: 0px;list-style-position: inside;}The time settings is under the top panel of the clock-radio. Turn the device to the back. There are two screws at the top and a message saying unscrew them to take off top. Remove the screws and take the top off. You might have to pry it off a bit. There are white buttons underneath the plate. Press the "time" button and then use the back-forth buttons on the front to adjust the time. You have to adjust the time minute-by-minute. There is no hour button. You have to keep holding down the forward-reverse keys until you get to the right time. Replace the top panel and screw in the screws to put back together. You might have to open the CD door to pull the panel through the front catches. And that should do it. (By the way, this is a hotel clock radio, not a vacuum cleaner!)
Aug 22, 2010 | Vacuums
Toyota 08600-00938 Car Stereo serial No. P9B00302
For our Toyota Prado 2001 01, after the battery had been removed SEC was showing on the cd / tape / radio display. To remove the security SEC warning, find the last 3 digits of your VIN number (under the hood) hold down the "TUNE" button and then press "1"
Then use the numbers 1 2 and 3 to type in the last 3 digits of your VIN number.
Quickly hold down "SCAN" button, the radio will power off, then press the volume button to turn it back on.
-I accidentally held down "auto" before holding down scan, I don't think auto has any part of fixing this (just an error on my part) but if the above doesn't work, you could try hold AUTO down after entering the digits then hold scan - just as I did.
Hopefully SEC has now been removed, enjoy your radio!
Mar 04, 2010 | Car Audio & Video
Can't tune my radio station to cd/mp3 car stereo, not sure of make doesn't state. only info to go on is acoustic solutions ics-30 rds compact disc digital audio
Try holding the reset switch for 5 seconds. It's located under the front unit/fascia of the stereo so you'll need to take that off.
Aug 15, 2009 | Pioneer DEH-3700MP CD Player
Need operating manual for Zenith Model Z253W radio
1. Tune the radio to the frequency you want to preset, using the "Tuning/Set" buttons.
2. Press "Time Set" button to enter set mode. Note it says "Preset" below this button, because it is used to set both time set and presets.
3. Select the preset number you want, using the "Preset" buttons.
4. Press "Time Set" button again to exit set mode.
5. Repeat the above process for each preset.
Nov 15, 2008 | Zenith Audio Players & Recorders
Help to be able to tune in radio stations
Thank you. I was able to find the manual on line and it seems that I need to have the remote to adjust problem. Will call Panasonic parts to find out how much it will cost. Have a nice day. Lh1953
Jul 06, 2008 | Audio Players & Recorders
I need help
On the front of the system, press and hold Clock button until the hour flashes. Then press the Digital tuning arrows for up or down. Watch the display for AM or PM. Stop on your hour. Press and hold the Clock button again til the minutes flash. Press the Digital Tuning arrows again for up or down. Immediately press Program Set button under the Digital Tuning arrows to set the program in. If you do not press Prog Set soon enough, you will have to do the whole thing all over.
Apr 22, 2008 | RCA 100-Watt Stereo System With 5-CD...
Clock Setting ?????
When a station is tuned in the unit will decode the incoming clock data after 2 minutes will display the correct time when the 'DSP' button is pressed.
Note: some stations do not transmit a PTY or CT information & therefore the clock display may not be available.
For clock setting it is recommended to tune to a National Radio Station.
Hope This Helps.
Nov 12, 2007 | Goodmans CD / MP3 car radio GCE780MPT CD...
Top Zenith Audio Players & Recorders Experts
xalint1
xalint1
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
