Question about Krups XP7230 Compact Super Automatic Espresso Machine
Cant rinse or make coffee error code 5/1
We just purchased our Krups XP7230 and followed the instructions. Instead of getting to the "rinse cycle" screen (the manual says to rinse before making your first cup of coffee), it just says to fill the bean grinder ("filling of the machine necessary"), which we eventually just did and after preheating, it now it says Error code 5. So we turned it off and on and got to the same spot and now it says Error code 1. Any ideas? (We installed the filter that came with the machine and filled the water container to the appropriate height. We called technical service and they said they don't know what those errors mean and their supervisor would call us back.)
I have an EA8080 Espresseria, i also receive filling of the machine necessary, however on my model it requires me to place something under the steam nozzle and it pumps water through. I occasional get an error code 05.
I though this was associated with water distribution not the grinder itself.
Can anyone confirm what error code 05 means or what 'filling of the machine necessary means?
Posted on Feb 24, 2013
Etryj
Posted on Dec 24, 2011
5 Suggested Answers
  • 17 Answers
SOURCE: Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Posted on Aug 14, 2010
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
  • 352 Answers
SOURCE: Beans are too oily
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Posted on Dec 01, 2009
SOURCE: Krups XP9000 fully auto unit will no longer grind
Perserverance...it's cheaper.
Also found a limit switch which i think is thermal so once removed the grinder is operational again!
Posted on Jan 27, 2010
Krups XP7230 outgoing used coffee is not compact
Grinder is not working normally and probably inner plastic part which remove coffee from the grinder is broken.
Feb 28, 2014 | Krups XP Coffee Makers & Espresso Machines
Machine fault error No 0C
0C
Faulty communication between the 2
boards
Disconnect and reconnect the
coffee-maker
Overconsumption on low voltage power
supply: Distributor blocked, does not turn
Determine the cause
Dec 16, 2013 | Krups XP7230 Compact Super Automatic...
Error code oa will not preheat
you need to get to an authorized service center.
Try http://www.smallappliance.com/repairsmain.asp?cur=USD
Mar 04, 2011 | Krups XP7230 Compact Super Automatic...
Looking for down loadable instructions for krups xp7245
You can download the instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 30, 2010 | Krups XP7230 Compact Super Automatic...
Error code 06 on a Krup XP7245
remove calk-filter in watercontainer..
Jun 28, 2009 | Krups XP7230 Compact Super Automatic...
XP7230 does not work with Claris F088 filter cartridge installed
You have the filter screwed it too far. As soon as you feel the filter seating do not screw it in any further.
Apr 30, 2009 | Krups XP7230 Compact Super Automatic...
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Sep 27, 2008 | Krups XP7230 Compact Super Automatic...
Krups XP7230 Compact Super Automatic Espresso Machine Logo
3,362 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
