Hard drive full on sentient n05jj - Computers & Internet
Hi have sentient cctv hard drive but the power light his flashing no pictures on screen
Check the monitor first to be sure it has not failed. Use another monitor or a flashlight against the screen of the one you have to verify there is no image.
Feb 18, 2017 | HIS Computers & Internet
Sentient cctv support
You may have to do an online search for one of several suppliers of OEM remotes.
Sep 06, 2014 | Televison & Video
I have a sentient n82gb that will record for about 30 mins then stops working and displays the message, cannot see hard drive. Can you help?
this might be because your computer is starting to get hot due to dust which causes static electricity clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
also one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 29, 2011 | Computers & Internet
Cannot delete events from Sentient N663HH 4 camera DVR system.
go to hard drive setup
you will need to overwrite over it.
go to overwrite on your set up and select yesto enable to overwrite harddrive when capacity is full
May 20, 2010 | Cameras
I have a sentient CCTV Hard drive recorder. Was working, but now shows no picture on the monitor. Power supply light on but does not work.
Unfortunately it is past DIY stage. Consult a service center.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 05, 2010 | Home Security
Sentient dvr cctv playback
Hi, I have a maplins sentient model Sentient dvr cctv is there a windows 7 PCviewer programe ?
Mar 30, 2010 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
