Question about Cuisinart CBK-100 2-lb. Bread Maker with Brushed Stainless Housing
Cuisinart breadmaker cbk-100 paddle doesn't turn
Paddle will not turn. The motor runs
2 Suggested Answers
SOURCE: pan is stuck in my cuisinart cbk-200 breadmaker.
Just pull it.
I had the same problem few moments ago until I read someone's answer.
It really worked and it won't brake.
Posted on Dec 25, 2009
Cuisinart cbk-200 bread pan paddle does not turn.
Your drive belt is probably broken or has slipped off. Unplug your machine and turn it on its side (remove the pan and paddle first) and remove the bottom panel with a screwdriver. Most bread machines have a removable panel. Hopefully yours is one of those. You will then be able to see if the belt is broken or has slipped off. You can reach me at breadmachineshelp.com for reinstall or replacement of your belt. If your belt has a number code on it I will need that. It will look something like this: STS 60 S3M471 If it has no code on it I still may be able to figure out the belt you need. Again, reach me at my website: breadmachineshelp.com
Mar 18, 2013 | Cuisinart CBK-200 Bread Maker
Motor runs paddle does not move
Your drive belt is probably broken or has slipped off. unplug your machine and turn it on its side (remove the pan and paddle first) and remove the bottom panel with a screwdriver. You will then be able to see if the belt is broken or has slipped off. You can reach me at breadmachineshelp.com for reinstall or replacement of your belt.
Jan 06, 2013 | Cuisinart CBK-200 Bread Maker
My bread pan doesn't sit correctly so the paddle doesn't move around well, especially when it kneads faster
First pull the springy steel clips out so they bend some and stick out a little further this will hold your pan in better. Before putting your pan in make sure the little ears on the underneath side of the pan are lined of roughly opposite of the pan ears in the bottom of the oven that push the paddle around. If that doesn't make sense contact me.
Oct 01, 2011 | Cuisinart CBK-200 Bread Maker
The paddle on my CBK200 slips off of the shaft very easily. This machine has been perfect, but the paddle does not seem to lock now.
Unless it is coming off during the cycles there is no problem. You actually want the paddle to be a little loose so it comes off for cleaning.
Aug 07, 2011 | Cuisinart CBK-200 Bread Maker
Mix cycle does not mix add ins evenly or thoroughly. Nuts and seeds are mostly left in bottom of pan or lumped in a few spots in the bread
Check the belt on the motor. It could be lose or has fallen off. Also check the motor to see that it turns in a kneading cycle and check to see if you can spin the paddle freely by hand. Hank
Jan 11, 2010 | Cuisinart CBK-200 Bread Maker
Pan is stuck in my cuisinart cbk-200 breadmaker.
Just pull it.
Dec 12, 2009 | Cuisinart CBK-200 Bread Maker
Bread kneeding paddle worn out at shaft
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Sep 06, 2008 | Cuisinart CBK-200 Bread Maker
Cuisinart CBK-100 2-lb. Bread Maker with Brushed Stainless Housing Logo
54 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
