Question about Food Processors
Need center post with interlocking safety latch for my farberware food processor
ThaMp3Doctor
  • 8596 Answers
SOURCE: safety-rod of bowl does not depress microswitch of Cuisinart processor
Cuisinart does not have the original pieces available, but you can order a replacement work bowl, lid, sleeve, etc that will work from the company. First do a motor test to make sure the motor is still working:
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Posted on Nov 25, 2008
ukvacfan
  • 328 Answers
SOURCE: Broken food processor lid
Check EBAY UK for any older models = you might not be able to get the lid on its own - Moulinex parts are difficult to come by unless they are still being made. Failing that visit UK shops such as Cash Converters or similar - you can sometimes find these food processors there.
Posted on Jan 02, 2009
  • 24 Answers
SOURCE: GE Food processor knife blade, bowl and cover .
plz con-022-23095757 / 23051554
Posted on Feb 03, 2009
  • 10865 Answers
SOURCE: Slicing Grating Blade for a Farberware 286 food processor
go to this site and you can order what you need:
http://www.smallappliance.com/department.asp?cur=USD&sid=18956&gid=18970&shopBy=Category&cam=drg_247-10377&drg=247-10377&gclid=CPPEqdb6zZgCFQw9GgodtGMO1A
Posted on Feb 08, 2009
  • 17 Answers
SOURCE: food processor lid interlock tab
Unfortunately, you can't glue it back on with any amount of long term success. Your best solution is to look for a new lid on Ebay or you can buy parts at GourmetDepot.com. They have the widest selection.
Posted on Jul 20, 2009
I need a replacement bowl for my Farberware food processor
Try checking here:
https://www.partstore.com/Content/CategoryPages/Appliances-Food-Processors.aspx
Dec 06, 2014 | Food Processors
The bowl on my cuisinart food processor is locked in place. How can I unlock it to remove the bowl?
You don't say what model, but all Cuisinarts have a safety interlock built in to the bowl assembly. The cover must be removed from the bowl to release this interlock before you can remove the bowl from the motor base.
Apr 20, 2014 | Cuisinart Food Processors
The food processor stops working after use. I know there is a reset "hole" to make it start again. I can't see where it is and cannot find it in the manual. Please tell me where it is so I can...
Not all food processor have a reset button, some don't have. You have to be make sure that the unit is in fit, suited because it will on the interlock switch (the safety switch) before it operates normally.
I hope I give you idea regarding your food processor problem.
Mar 27, 2011 | Cuisinart DFP-14BC Custom Food Processor
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
Food processor not working
Latching seems to be a sometimes thing.
I have this problem and found that I could make it latch by holding the body of the machine firmly and turning the lid while forcing the machine and processor lid toward each other ( This worked 7 out of 9 times).
You can also manually trip the little lever (to the left) inside the slot the lid rotates into.
This will leave the machine's interlock switch always on ......... but this can change with removal and replacement of the processor lid.
May 06, 2009 | Bravetti Platinum Pro Quad-Blade Food...
I cannot get my processor to start
Food processors are notorious for having safety interlocks. If everything - and I mean everything - isn't attached in the correct sequence and clicked into place, one of the safety switches may not be engaged.
You can test it by switching back to the setup you used before to see if it will still operate. If so, then CAREFULLY review all the steps needed to use the new setup.
Mar 12, 2008 | Cuisinart DFP-14BC Custom Food Processor
Food Processor won't turn on?
Food processor housings MUST be assembled in a certain order. And each part usually clicks or snaps into place. When all parts are PROPERLY assembled, the safety interlock switch will engage. Until then, no workee.
Mar 05, 2008 | Food Processors
Food Processors Logo
87 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
