Question about Philips Magnavox 27MS343S 27" TV
MAGNAVOX 27" TV, PICTURE START UP PROBLEM
WE HAVE A 27" MAGNAVOX TV, PICTURE HAS GONE OUT. IF WE DO A CONTINUAL ON/OFF WITH THE TV THE PICTURE COMES ON A LITTLE WITH SQUIGGLY LINES THEN GOES OUT. WE CONTINUE THE ON OFF MODE UNTIL THE PICTURE STAYS ON ALL THE TIME. BUT WE HAVE TO GO THROUGH THIS EVERYTIME WE TURN THE TV ON. WE HAD A GENTLEMAN SAY THE START UP SWITCH IS BAD, BUT NOT SURE. HOW DO WE ORDER THE PART AND DIAGNOSE OUR PROBLEM. THANK YOU. SUSAN LAWSON
    President:
  • 814 Answers
This problem with your television set is more than likely a problem with intermittent component failure. The fact that the television turn on for awhile is a sign the the component or components are intermittent.The reason the television turns off is that it goes into the protection mode caused by the intermittent component or components. They are unstable and are causing unstable voltages supplies to appear in the circuits. The television has a built in feedback circuit that will detect the faulty operation and turn off the television. When it stabilizes again the television turn back on. This is usually a sign of aging or faulty components. The problem will only get worse and the television should be thoroughly tested. You can call Magnavox customer support at this telephone number 1-800-705-200. Give them the model number of your television and tell them about the problem you are having with intermittent turn on of the television. They will be able to tell you where to take the television for testing and service. I hope this information helps you with your problem.
Posted on Jun 02, 2009
Philips Magnavox TV TS 3260 C121
Audio decoder section circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 22, 2016 | Philips Magnavox 27MS343S 27" TV
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
Screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
No picture on magnavox hd tv
Contact your Direct TV provider = they will refresh your source box...............................T.
Nov 30, 2007 | Philips Magnavox 27MS343S 27" TV
Philips model ptv915 model # 60P8341a
  • sound  off & on is dye to loose contact in sound section
  •  plz check
  • speaker wire or connector loose.
  • speaker defective.
  • loose contact or print loose in sound section.
  • supply to sound section.
  • sound output ic or print loose.
  • hopr this will help
  • good luck.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
1998 27' magnavox tv/combo
Frame width is normal means. Check aspect ratio is changed in menu options. Even width is also enlargement means there is high output from power supply section. Check and change the high voltage filter capacitor.
Sep 09, 2007 | Philips Magnavox 27MS343S 27" TV
Magnavox hdtv
The Magnavox 27MS343S is a standard analog 27" TV. It is not high definition and therefore cannot generate a posterized or pixelated picture. I will bet you are using a digital cable box or satellite reveiver and the problem is in that box, not the TV. Hook up a regular VCR to the TV, set the TV to channel 3, put in a good pre-recorded tape and hit PLAY. If the tape plays nice and clear on the TV, the problem is in your digital box.
Sep 07, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27" TV - no picture and buzzing sound
Are you using the video input? Do you get on screen display? If so you probably have the video (yellow) wire connected to one of the audio inputs.
Feb 08, 2007 | Philips Magnavox SC3127N 27" TV
Philips Magnavox 27MS343S 27" TV Logo
231 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
