Question about Cell Phones
Zte problem my new ZTE Majesty phone got wet. I dried it for 48 hours in rice. It now works but will not go into "sleep mode". It constantley changes screens from ZTE logo to Tracfone Wireless logo and then to wallpaper phone - then starts over again. It only does not do this when I'm actually using the phone. Also the battery runs out in just a few hours as it will not turn off unless I manually power off. Is there any way to fix the problem?
3 Suggested Answers
  • 44 Answers
SOURCE: my phone will not power up past the tracfone blue logo screen what should i do??
The below steps will resolve many small issues.1.Power off the phone.
2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.
3.Use "Vol+" and "Vol-" to move the cursor up and down.
4.Move cursor to "wipe data/factory reset", press "Back" key to select it.
5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.
6.The data will be erased.
7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.
WARNING: All user data will be completely cleared; the phone will be in a factory reset status.So before you reset backup data first!! gud luck!!
Posted on Feb 25, 2013
  • 17 Answers
SOURCE: zte score stuck on muve music screen loop
Hey i've been workin on these ZTE phone and i guess all u need to do is a reset. But the only problem is u will lose all ur data. all u gotta do is First power off the handset, press the Camera key + Power on key +Down volume key together at the same time.
when restart the handset,When display "ZTE", press the Menu key at the bottom of the screen;
Choose "Wipe data/factory reset" through volume key
Press "Camera" key to confirm the above item
Choose "YES...delete all user data"
Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Now once its done ur phone will automatically configure all the factory setup and should work fine,
Posted on Apr 09, 2013
Testimonial: "thank you.....its only been locked up for 8 months......that was too easy....I always over think things.......thanks again "
My zte zmax phone was dropped in water stop charging two days later start charging again but now the power button isn't functioning how could I fix it
your going have to take the phone apart and put all pieces in bowl of dried rice let it stay for at least 24 hours re assemble unit and everything should be okay
Sep 16, 2015 | ZTE Cell Phones
I have a ZTE Majesty cell phone and I have water damage, where can I get it fixed?
Hi Michele
Try placing the phone in a bag of rice for 2 days or even 7 days.
The Rice should suck up all the moisture and if your lucky it will have no damage and will start up again.
Good Luck
Wholesale ZTE Cell Phone Accessories Distributor
ZTE Phone Repair ZTE Phone Screen Repair Services Nationwide
Jul 08, 2015 | ZTE Cell Phones
How can I root ZTE majesty window 7 android?
Its running android 4.1.2 which is Jelly Bean and is hard to crack, you could give Towelroot by geohot a shot usually works for a lot of devices.
Feb 20, 2015 | ZTE Cell Phones
My zte majesty got wet, put it in rice, phone turns on but screen is black?
looks just like any other electronic device, I suggest that you clean it. It really does not matter how much water exposure it had, or how long the exposure was. what matters is which part was exposed. Disassemble your phone and clean every part, connector and cable with 90%+ isopropyl alcohol. Make sure that you remove any EMI shield. Use a soft brush to clean the connectors and cable ends properly. Check for missing or burned components. Once it is cleaned, replace the battery. After that reassemble your phone and re-evaluate. Until you know for sure that it is clean, any answer will most likely be a guess only. Hope this helps, good luck.
Jun 26, 2014 | ZTE Warp
How to reestablish connection for camera on zte majesty phone
hi Lynn King, there should be a icon for the camera, and you simply press there.
You find the manual here and the camera feature is at page 54-55 :
http://theinformr.com/upload/manuals/zte-majesty-manual.pdf
Jun 09, 2014 | ZTE Warp
Why does the screen on my zte majesty gradually turn a transparent gray
Sounds like a power stand by feature. Try entering the settings of the device and inspecting its current power save feature. You will likely need to adjust it to start power saving at a longer period or turn the feature off all together. I'm not completely familiar with that device but that sounds like the problem.
Apr 28, 2014 | ZTE Score
What can i do to fix my phone that doesnt respond after it got wet?
Take it apart IMMEDIATELY and remove the battery. Then pack both of them in rice to absorb the water. If you have other water absorbent material even better. Leave it there for at least 2 days to dry - be patient. Maybe you can start it again if it's totally dry inside.
Apr 26, 2014 | ZTE Groove Cricket Wireless
How to fix a zte when it got in water
Wet Cell Phone
Immediately remove the phone from the water, turn off the cell phone, remove the battery and SIM card. To dry out the cell phone put it in a large plastic bag with silica gel drying crystals then put it in a warm sunny place for several days or in front of a warm fan heater for several hours. Reassemble the phone and hope it will work properly again, but if does not work then it is faulty and you need a new cell phone.
Jan 10, 2013 | ZTE Warp
Zte warp got wet
When this happens, immediately remove the battery. Let the phone dry (it may take several hours) before you put the battery back in and try to turn it on. If it is only water, and you act quickly enough, your phone may be okay.
Oct 22, 2012 | ZTE Warp
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
