Question about YouTube Videos
*** poran hub - YouTube Videos
Replace front hub assembly 2002 Suzuki XL7
the front wheel bearing hub?
XL-7 (the dash matters)
my wild guess, is the questions was
what are all steps to do this job. and tools.
that?
RTM?
https://suzukipitstopplus.com/Products/10056-2002-grand-vitara-xl-7-service-manual.aspx
http://www.fixkick.com/hubs/FW_BEARINGS.html#newer
the link shows all years, and variances.
here is a photo review, that is accurate up to
1998, and beyond , if you skip the bearing service parts. as yours are INTEGRATED
and NON-serviceable.
the photo 6a and B
shows removing the hub,
so do that , buy a new hub and put it back
the same way, using the tool stated
at the stated ranges of torque
123-180 ft/lbs.
this range allows you to get the screws into the locking rings.
Dec 11, 2016 | 2002 Suzuki XL-7
I have hub4 friend giving me hub 5 so I just change it over and that all I do
Should be just a changeover the hub is not very intelligent so there should not be too much issue. Speed of hub ports ? 10/100/1000 Mb/s
hubs basically repeat the network packets to all ports .
what feeds into the hub what speed is it at and what speeds does the hub support is the only issue you may have. Assuming you have ethernet hubs.
MUST use 5 hubs power supply AC to DC adapter with the 5 hub device.
do not just pull power plug out of 4 hub and put it in 5 hub device unless you know they are compatible with same DC voltage and current rating it is much simpler not to mix them up.
Sep 13, 2016 | Computers & Internet
How to torch the hub on a 92 geo tracker 4x4
torch?
you mean TEST?
HUB the front bearing hub or the axle end locking hubs.?????
auto or manual hubs>?
test
http://www.suzukicarparts.com/parts/1995/Suzuki/Sidekick/JLX/index.cfm?siteid=214820
fix hubs
http://www.fixkick.com/hubs/hubs.html
Sep 28, 2014 | 1992 Geo Tracker
How to repack front manual hub bearings on 1993 tracker 4X4
every fact on topic , hubs here.
it's not the locking hubs its the wheel bearings in its own hub.
dangerous condition that... very much so.
May 24, 2014 | 1993 Geo Tracker
How to change fornt drivers wheel bearing on grand vitara 2002 model 2.0 ltr 5 door and where can i get a repair manual for this model
REMOVAL & INSTALLATION
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Front wheel
    • Brake caliper and rotor
    • Locking hub or hub drive flange, if equipped
    • Hub grease cap, if equipped
    • Wheel speed sensor, if equipped
    • Wheel bearing lockwasher
    • Wheel bearing locknut and inner washer
    • Wheel hub and bearing assembly
    • Wheel hub oil seal
    • Wheel bearing oil seal
    • Snapring
  3. Press the wheel bearing and race out of the hub. To install:
  4. Press the wheel bearing and race into the hub so that the race is fully seated in the hub bore.
  5. Install or connect the following:
    • Snapring
    • Wheel bearing locknut and inner washer. Tighten the nut to 157 ft. lbs. (216 Nm).
    • Wheel bearing lockwasher. Tighten the retaining screws to 13 inch lbs. (1.5 Nm).
    • Front wheel
prev.gif next.gif --- Go to your local auto parts store or library to get a copy of the repair manual for this model.
Aug 26, 2010 | 2002 Suzuki Grand Vitara
I have i 95 kia sportage and the automatic hubs won't lock the 4 x4 light turns on and in 4 lo the gearing changes but only turns the rear wheels i just bought the car and didn't know the 4x4 didn't work...
Remove the automatic locking hubs from the vehicle. You will probably notice on one hub or the other the alloy tabs that extend from the inner part of the lockout hub are sheared off, they will probably be found loose in the hub or near the bearing. The manufacturer Warn makes a good replacement automatic hub for the Kia Sportage; Warn part # 61918 for the automatic hub or if you prefer the manual hub Warn part # 60247. The hubs come with excellent instructions to remove the existing hub parts as well as the installation of the new hubs. This seems to be a common failure with the Kia Sportage and almost certainly is your problem.
Oct 24, 2009 | 1995 Kia Sportage
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
I can't get the hub off to replace the rotor.
4X4?..Then you have to remove the lock-out,then use a hub socket which is about 3 inches in diameter with 4 notches in it to remove the ratchet nut inside the hub..then after the hub is off,put a lug nut on the studs and hammer them down out of the hub and the hub should come off.you may have to hammer on the hub all the way around because the rotor and hub fit together pretty tight.
May 17, 2009 | 1992 Ford F150 SuperCab
Hub not working properly
Maybe your hub port is not using auto sense port.
Aug 30, 2008 | 3Com (3C16593BN) 24-Port Ethernet Hub
ESHUSB-4P hub problem
Your hub ma have been a older version of USB and the new computer has the USB ver2. in this case the hub is not talking to the computer. the computer USB is not backward compatible and will to detect the hub. you will need a new hub.
Aug 20, 2008 | Encore ENU-4USB 4-Port External Mini USB...
YouTube Videos Logo
29 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
