Question about Garden
Electric mower not starting.
I have a Craftsman electric mower (18" cut) which stopped suddenly, as if the cord if the cord was pulled out. Does not start anymore. Checked that cord is OK, and electrical outlet is live. Is there a reset or internal fuse on this machine?
  • Anonymous May 20, 2009
    I have the same problem and can't find a fuse anywhere.
    Allen
I have no idea if your problem is related to mine, but my B&D electric mower did the same. The cord worked on other equipment so wasn't a bad cord. It turned out I had to get a higher amp cord for the mower. Why it worked for a while on the other cord I don't know but I've had no further problems with it. The cord was expensive though.
Posted on Jun 06, 2009
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
What to do when craftsman mower pull cord won't recoil?
Sounds like the spring inside the recoil has either broken or let go so it won't recoil. If you are lucky it could be the wheel that the cord goes on is seized or stuck. You can take the recoil off most mowers by taking out two or three screws and lifting it off the engine. They can be repaired but it takes time having to be careful the spring won't spin and hurt you. I have even taken a recoil off another engine and if the holes for the little screws don't line up just drill little holes beside the old ones and reinstall the little screws.
I even used a 18 volt cordless drill to crank the engine using the bolt on the fly wheel and the right size socket. Leaving the recoil off You have an electric start that way.
Aug 30, 2014 | Craftsman 21" 190cc Rear Bag High Wheel...
No start on a mm 1800 18"
check the cord for cuts then check the safty engagement on the handle and make sure it disengages to cut thats about all you can do turn blade make sure turn freely not plug in after you will have to take it in
May 31, 2014 | Black & Decker Black and Decker Mm575 18"...
10 year old Toro 2017 lawnmower, suddenly stopped while cutting grass. Oil quite low. Cannot pull cord more l than few inches.
When you pull the cord does it hit a hard stop and not go any further or does it get really difficult?
Aug 02, 2011 | Toro Lawn Mower With Toro Power Tools
I have a black and decker 18 in lawn-mower. I bought a haeavy duty extension cord to connect power to the lawn mover. It was working then suddenly it stop and blew the switch. I plug the cord to a...
I would say the outlet/ cord. here is a recommended types and lengths of extension cord, Tim:
http://support.mtdproducts.com/app/answers/detail/a_id/435/~/what-type-%26-size-of-extension-cord-can-be-used-with-an-electric-mower%3F
May 29, 2011 | Black & Decker Black and Decker & Grass...
I was cutting 16" logs
The motor is locked up.What it did is seized the rod too the crank.Hate to say it but it,s time for a new saw.
Nov 29, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
18" mower suddenly stopped working
motor problem.if you hit something stone our water springler may be the motor magnetic ring broke & jam the armature & not
to start & house pop. see toolpartsdirect.com looks for the model of the mower. black & decker
Feb 08, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
172 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
