Question about Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi
Porter cable framing nailer trigger lock - Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi
rowdy45176
  • 2176 Answers
SOURCE: porter cable fc350a frame nailer shoots just air
Could be a couple things, first are you using the right nails in the gun e.g. collation and degree. Second do the nails move freely in the magazine and how is the pusher spring on the nail does it have enough pressure. Then I would unplug from air remove all the nails andjust tap the nose on a piece of wood and does the driver drop? If so the piston Oring is worn and needs replaced, but if you do that I would recommend replacing all the rubber. Let me know and I would need the exact model number to come up with parts.
Posted on Jan 25, 2009
  • 1383 Answers
SOURCE: I have a porter cable fr350A round head framming
I have worked on many fr350 nailers with the problem that you are describing. The fix is usually simple. I just remove the head and pop out the headvalve by using an air nozzle on the small port drilled into the mating surface. Be carefull because the headvalve could pop-out with force. Clean all surfaces and use silicone paste to lube the orings and the surface of the head where orings contact. Check for cut orings or defective upper bumper (cracks or cuts). Also look for small scratches with magnifying lens on the surface where orings contact. Sand with very fine paper (300 grit). Re-assemble and you should be good to go. Silicone paste is sold at Lowes in the plumbing department. It is used to lube orings in faucets. Parts are available at www.toolpartsdirect.com
Good Luck on your repair and email if you have questions.
Posted on Mar 20, 2009
  • 1383 Answers
SOURCE: PORTER CABLE FR350 FRAMING NAILER RAPID FIRES
I have seen this problem on several brands of nailers. The solution in most cases was to make sure headvalve orings are sealing correctly. Here is a simple test. Remove the head and place on workbench with gasket surface facing up. Push headvalve all the way in with your thumbs then cover the vent hole with finger and release thumb pressure to headvalve. Vacuum should keep headvalve down untill you release finger at vent-hole. If vacuum does not hold, remove headvalve and examine surfaces for fine scratches and/ or make sure of correct size orings (headvalve should be very snug). Remove scratches with extra fine paper (300-400 grit). If headvalve holds, remove headvalve piston and piston stop. With headvalve spring removed, push piston stop into headvalve and make sure that the piston stop fits snuggly into piston. Also make sure piston stop is not damaged or cracked. A loose fitting piston stop will cause multi-fire. Replace as necessary. Upon re-assembly, lube all rubber parts with plenty of silicone lube (not oil, wipe clean all parts before lubing). Silicone paste/grease is sold at Lowes in the plumbing department (Danco Brand). Good luck and email if you have other questions about this gun.
Posted on Jun 16, 2009
SRF518
  • 232 Answers
SOURCE: I have two Porter Cable pneumatic nailers, one a
the triggers are held in place in the handle with two roll pins. the trigger itself operates off a hinged paddle inside the trigger. this paddle won't operate unless the safety is depressed. both safeties have a return spring. if yours are missing nothing will work. go to porter cable parts site and purchase the correct parts
Posted on Oct 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: Porter Cable FN250B nailer won't nail.
it sounds like there is a jammed nail in the nose/magazine or possibly a bent or broken driver. UNPLUG the air and remove the top cap carefully and see if the piston is twisted in the cylinder. Let me know and I will try and find you a breakdown for this tool
Posted on Nov 06, 2009
How do I replace the trigger valve assembly on a Porter Cable DA250C nail gun
There is one pin with a retaining o-ring that must be removed holding the trigger arm in - then there are 2 roll pins that must be driven out with a small punch that hold the trigger valve. Once the 2 pins are removed the trigger valve can be pulled straight out.
When you install the new trigger make sure the recesses in the trigger line up with the holes for the retaining pins.
Porter Cable DA250C Type 1 15 Ga 2 1 2 34 Angle Finish Nailer Parts
Feb 12, 2015 | Porter Cable Air Tools & Compressors
How do I release the trigger lock on a brand new porter cable nail gun
Are you depressing the nose of the nail gun against the material to be nailed first? Without doing this, the trigger will not "unlock". You can read a pretty in-depth review of this nail gun at OnlineToolReviews com Porter Cable FR350A Full Round Head Framing... which might also help.
Jul 16, 2014 | Porter Cable FR350A Factory Reconditioned...
Breather Valve
The Porter Cable FR350A has a head valve (PN A08650) and a trigger valve (PN A08368) but no part called a breather valve. What is your question?
Jan 18, 2013 | Porter Cable FR350A Factory Reconditioned...
Porter cable 350mag framer pin wont go back in and air coming out of the exhaust...It is brand new I used it on a deck today and this happened!!!
FIRING VALVE IS STUCK IN OPEN POSITION, FIRING VALVE IS IN THE CAP OF THE TOOL. REMOVE IT AND OIL THE ORINGS. ALSO COULD BE DEFECTIVE TRIGGER KEEPING FIRING VALVE OPEN
Sep 02, 2012 | Porter Cable COIL350 3 12" Magnesium...
I have a Porter Cable FR350A Round head framing nail gun, but I dont have none of the accessories in the box. The manuel extra trigger or what ever else that comes in the carrying box when you puchase a...
Parts /extra trigger for your gun are available at your local dewalt service center or at www.toolpartsdirect.com. Some of the triggers that come with fr350a as standard equipment had a small red button on the side that allowed you to select single shot mode or multiple. If your gun has a black metal trigger, it is better quality/lasts longer than black plastic. Good hollidays
Dec 30, 2010 | Porter Cable FactoryReconditioned DA250BR...
I have a poter cable brad nailer and after running
Sounds like a trigger seal. I assume this is an oil-less brad nailer as that is the standard. You should be able to find the seals at any local hardware store including Home Depot or Lowes. If you can't find the portercable O-rings just grab the random assortment from Bostitch which is usually readily available. Refer to your parts manual for the correct size/gauge
Apr 15, 2010 | Porter Cable Cable Brad Nailer and...
Porter Cable FR350 Round Head Framing Nailer not firing
check and make sure your compressor is at the right psi. 120psi. is there any nails stuck in it. there may also be a problem with the seals.
Mar 08, 2010 | Garden
I have a FC350A FRAMING NAILER, IT IS IN THE
check to make sure that there is not a nail jam , if the driver will not retract then the gun will not cycle . if no nail jam then replace the inner trigger
Feb 02, 2010 | Air Tools & Compressors
I have two Porter Cable pneumatic nailers, one a finish and one a brad. Both of them have suddenly quit working. The triggers are loose and not engaged to anything. Somehow the mechanism is not rebounding...
Oct 22, 2009 | Porter Cable Tools & Hardware - Others
Framing nailer intermittently doesn't shoot the nail.
Make sure to blow out the magazine where the nails load, make sure the spring tension on the nail clip is working properly, make sure you're not holding the clip somehow with your off hand so the clip can't feed correctly.
Apr 20, 2009 | Tools & Hardware - Others
Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi Logo
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
