Question about Whirlpool Washing Machines
What is the capacity of whirlpool washer model LSR8233JQ0
  • 351 Answers
SOURCE: whirlpool super capacity washer spin cycle stop working
Sounds like you need a new lid switch. Click HERE for prices.
Posted on Apr 19, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool Washer LSR8233JQ0 won't spin
You have a Bad transmission if the motor runs in spin but no spin .
Posted on Jul 18, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: WHAT IS THE CAPACITY SIZE OF MY WHIRLPOOL DUET
3.8 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
jumptrout51
  • 3361 Answers
SOURCE: where do i find the model number. whirlpool super
Under the lid.
Posted on Jan 30, 2011
Testimonial: "thanks,did notice after txting but nice to have it confirmed."
What is the capacity of whirlpool model #LA5558XTW2
This is a direct drive model washer tub size is large capacity but any washer to stop from overloading is loose laid cloths 3/4 of tub any washer to work properly
Dec 19, 2016 | Whirlpool Washing Machines
Need to know the year model of a whirlpool washer & dryer that belonged to my mom? The dryer Model #LER6848AWO and the washer Model #LSR7233BWO?
Mar 2009 dryer model #LER6848AWO serial and the washer model is Aug 2010 ... Model Number: LSR7233BWO. Hope you find this useful.
Apr 19, 2011 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
What is the capacity of washer model GHW9400PW0
Whirlpool GHW9400PW Washer / 27" Duet Front-Load Washer w/ 3.8 Cu. Ft. Capacity, 13 Cycles & 1200 RPM
Feb 05, 2010 | Whirlpool GHW9400SU Front Load Stacked...
LSR8233JQ0Washer won't fill
The water is syphoning out the drain hose.
Many times when the stand pipe is backing up someone will seal the washer drain hose to the pipe to avoid overflow of the stand pipe.
This causes the water to syphon from the washer.
Or the opening for the stand pipe is just big enough to put the drain hose in and is to tight causing the syphon.
Putting the drain hose to far down the pipe can cause a syphon also.
Jan 20, 2010 | Washing Machines
Jul 18, 2009 | Washing Machines
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
296 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
