Question about RCA LED46C45RQ 46" LED TV 1920x1080, 4000:1, 60 Hz, HDTV
I CANT FIND THE CODE TO PROGRAM MY DIRECT TV REMOTE FOR MY RCA TV
    New Friend:
  • 16 Answers
A Genie RC71 remote works On My RCAI did have to get DTV help for it. My Old RC65 No Way. Both remotes work on My LG
Posted on Mar 17, 2014
SOURCE: need code to progam remote
The Model L32HD31R, according to RCA, is not "code compatible". It cannot work with a universal remote, or cable/satellite remote. this is peculiar for a company like RCA, however I just bought the same model from Wal*Mart, and companies build models for certain stores. This one was built on the cheap, and one of the things left out of the mix was the "code compatibility".
Posted on Jul 11, 2009
  • 73 Answers
SOURCE: RCA universal nor cable remote will program RCA L40FHD41 TV
might be able to use the cable co remote and autosearch thru the codes, but its too hard to explain, the cable tech should have ran that procedure. unfortunately, rca has 50 million models. it is common to have a tv and yes rca for sure, to not take the codes. sometimes the tv is too new for the cable company remotes to work. i am leaning toward the tv too new theory. give it six months and i bet there will be a new remote version.
Posted on Jan 21, 2010
SOURCE: directv remote will not program to rca L42FHD37R.
"This TV utilizes new remote control signal codes and may not be compatible with your existing universal remote (e.g. satellite box remotes, cable box remotes, generic universal remotes, etc.). Over time, newer universal remote controls that become available should pick up the new TV codes."
Posted on Jan 28, 2010
pabloloco
  • 2335 Answers
SOURCE: looking for the direct tv RC65R remote control
RCA TV codes for the DirectTV RC65 are:
11547, 11447, 10047, 10051, 10093, 12187, 12002, 11958, 11953, 11948, 11922, 11919, 11917, 11781, 11347, 11247, 11147, 11047, 10774, 10747,
10679, 10278, 10174, 10135, 10090, 10038, 10029, & 10018.
Instructions for entering the codes are here.
Instructions for searching for the proper code instead of trolling through that list are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
Posted on Apr 02, 2010
SOURCE: I need the 4 digit programming code for a RCA
hi! i have here a couple of codes for your RCA tv, just try them, 1143, 1196, 1241, 1242, hope this helps!!! goodluck!!!
Posted on Jun 09, 2010
How do I program my RCA TV with a RCA remote and DVD/VCR that is a JVC
HI,
CHECK THE FOLLOWING LINK . ON SEARCH TAB TYPE RCA . YOU WILL GET ALL THE LISTED RCA REMOTE CODES AND HOW TO PROGRAM IT.
Electronics Equipment Repair Center
Jul 13, 2014 | RCA RCU403N Universal 3 Device Remote...
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
REMOTE PROGRAM CODE FOR RCA D52W20
When I got Direct TV my TV would not program with the remote so I had to use separate remotes. That is what the Direct TV rep told me and now I have Time Warner and still have the same problem with one of the TV's. Hope this helps
Mar 24, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
I cant program my rca remote on the tv
Hello
Setup codes for Toshiba TV with RCA RCR 311B remote control are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
Most RCA universal remote will have this code for Toshiba TV.
Programming method:
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1* Manually turn on the component
you want the remote to control.
2* Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3* Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4* While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5* After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
OK.
Jul 14, 2011 | Toshiba 27A45 27" TV
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
I need to program 2 direct tv remotes to operate tv's as well as the direct tv box
here is a link with the code sets for this remote: direct TV remote codes
here is a link to programing guides: Programing a remote
choose your remote type and follow the instructions to program it.
Thanks and I hope I helped. Send a message if you have any questions.
Mar 17, 2010 | RCA DIRECTV Satellite Remote Control
RCA DIRECT TV UNIVERSAL REMOTE CODE FOR SONY TV
If you have the RCR450 remote, the manual is here =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
The codes for Sony TV are 1002, 1218 listed in the back of the manual.
Nov 08, 2008 | RCA RCR450 Remote Control
Finding codes
how program my control sanyo for tv curtis mathes
Sep 12, 2008 | RCA DIRECTV Satellite Remote Control
RCA RCU704 Series remote controlTrouble
I just purchased an RCA RCU704 series remote control and I followed all direction for both direct entry and code search.and still cannot seem to program my tv to turn off after repeatedly hitting the on/off button on the remote. What do i do?
Dec 25, 2007 | Televison & Video
Remote code
you can try : 0045,0043,0845,0154,0156,0060. Hope this will help.
Oct 14, 2007 | RCA T09084 9 in. TV/VCR Combo
RCA LED46C45RQ 46" LED TV 1920x1080, 4000:1, 60 Hz, HDTV Logo
376 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
