Question about Poulan Pro 25hht 25cc 22" Gas Hedge Trimmer
Wont coil back into its housing, so trimmer wont start. Has compression though
How do I change the recoil starter on the homelite 26ht (hedge trimmer)?
    Problem Solver:
  • 11 Answers
Hi, this a cut&paste from elswhere but it applies to your problem:
how to repair a recoil spring: whats missing is this, you should always wgear eye protection when dealing with springs of any kind.
remember safty first. :)
Remove the recoil shroud and take a look at the assembly.
You might have a broken spring or just a rope that has slipped out of the reel.
The spring usually breaks at one of the end tabs. If so, you will need to get a replacement spring and carefully wind that in, before re-assembling the rope reel. You might wish to replace the rope also, if it shows signs
of wear.
You will need to remove the entire cooling shroud. There should be 4 bolts on the sides. You might need to remove the fuel tank also. Pre-wind the recoil reel by hand [about 6 turns, to set the spring tension] and clamp it with Vise-Grip pliers. Remove the old rope. Thread
the new rope through the shroud housing eyelet and to the reel hub. Let the reel re-wind itself until it is full. If there is not enough spring tension you can wind it a couple of turns more by slipping the rope around
between the reel and shroud. Re-clamp the reel. Cut the rope to length and thread it though the handle. At all knots, burn and melt the rope with a
lighter to prevent untying. Re-assemble.
(special thanks to "Micheal"the author)
Posted on May 19, 2009
Starter rope is stuck, will not move when trying to start the trimmer
Smack the the f%%k out of the reel try to get some w/d oil on it then get a new coil reel when smacking watch for string whip
May 31, 2014 | Homelite Factory Reconditioned 26cc...
Cant remove pull rope housing from homelite gas hedge trimmer
there is a screw in the hole of the clutch housing bell torx bit i think its a #20
Jun 04, 2012 | Garden
My 26HT reconditioned trimmer will start and run on full choke but, if I take it off to middle choke, it dies. It doesn't run right on full choke but does rev up enough to engage the blades. Has...
sounds like a carb problem You will have to take the carb off and strip it down to parts clean out all the ports with a good cleaner I use brake clean reassemble and reset the High speed and low speed jets at 1.5 turns out then adjust from there
Jun 14, 2011 | Homelite Factory Reconditioned 26cc...
Pull the chord and it just uncoils and recoils, not turning anything to start the motor.
You might have a broken latch inside the coil assy or maybe just gummed up or stuck. take it apart and look into it further. Go to this website and they have a video about restringing starter coils this will aide you in your disassembly. smalleng.com
Nov 20, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Homelite 21" hedge trimmer. Won't start. Has spark, compression, fuel (used a little starter fluid), checker spark arrestor and muffler (clear). I haven't torn it down to check the Woodruff key but it ran...
Abell, put a little drop of petrol in the plug hole, replace plug and give it a pull. If it fires up for a moment, it is a fuel starvation problem. Check the carb, clean and make sure the nedel valve in the bottom of the carb is not sticking. Good luck!
Aug 06, 2010 | Homelite Factory Reconditioned 26cc...
My rope is stuck in the out position.
you need to get a new coil / might be able to fix the current one but that can get a bit tricky when the thing snaps out all over your house. the retract coil has likely broken this is a major flaw of any pull start design.
Aug 25, 2009 | Poulan Ght225 25cc Gas Hedge Trimmer
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
No start; recoil starter hard to pull.
No. Sounds like the crankcase is filled with fuel.
Mar 24, 2009 | Garden
Poulan Pro 25hht 25cc 22" Gas Hedge Trimmer Logo
727 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
