Question about Linksys Wireless-G WRT54G Router
Intermittent/non-existant connection with LinkSys WRT54G router
Greetings. We have a Linksys WRT54G v1.1 router set up on our main floor office Dell PC. For the last month or so we have had problems with our upstairs office computer being able to get a signal from the router on the main floor.
Have tried unplugging the router/rebooting the PC's, etc., no luck.
The toolbar wifi messages alternate about every 2 seconds between "connected at 54 bps" and "not connected".
My iPhone gets the wifi signal clearly throughout the house, just the upstairs PC seems to be having problems of late.
Would upgrading the firmware or purchasing a Range Expander help?
Thanks so much!!
  • 31 Answers
I would get a Range Expander... it sounds like you are having problems recieving a constant signal. When you do get the range expander plug the Range Expander halfway between you upstairs computers and your downstairs where your router is at. I hope this helps!!
Sincerely,
cdixon18
The ManInsideTheMachine
Posted on May 19, 2009
Cant connect to my dell inspiron 8100
I think you should check the wireless settings of your router first.
If your wireless network is secured then make sure that you have the correct wireless network key WEP / WPA .
If your router is too old then it will be better to upgrade the firmware of your Linksys router.
Jan 01, 2012 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT54G which I have hooked up to my older Dell computer successfully. The signal is excellentfor this one, called "Bob" for clarity. I am trying to hook up to "Bob"...
Sounds like you may be experiencing excessive interference in the WIFI space. Try setting the linksys router to use a different wireless frequency. (normally the available ones are 1 - 11).
Jan 11, 2011 | Linksys Wireless-G WRT54G Router
I get limeted access to internet
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router's SSID or the wireless network's name, To change the router's channel, To enable the wireless security on the router, Log ionto your router, 192.168.1.1
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router's firmware on Linksys
Dec 08, 2010 | Linksys Wireless-G WRT54G Router
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
How view my office cameras using Linksys Wireless-G WRT54G Router
is your office camera connected to the wrt54g? do you know the ip address of your camera? the port number will come from your camera. If the camera is connecting to the wrt54g, you can open the router configuration page and input your settings there. Call linksys technical support for that. If linksys cannot help try http://technicalsupport.blog.friendster.com
Feb 21, 2009 | Linksys Wireless-G WRT54G Router
Linksys rangeplus drops wireless connection ever 5-10 mins
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 19, 2009 | Linksys Ultra RangePlus Wireless Routr...
Continuously lose connection
For the Firmware update go to :www.linksys.com
Thanks, Joe
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Make my existing wireless connection secure
Ginger,
I am back online if you need help. I will be online most of the day tomorrow.
Thanks,
Brad Nelson
Mar 23, 2008 | Linksys Wireless-G WRT54G Router
Linking wrt54g with actiontec m1424wr
You need to check the ip address of your actiontec router, the default ip address of linksys router is 192.168.1.1, they should not be the same or else you will not able to connect the router to the internet.
To access the router web configuration
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3676&p_sid=fvzPHEYi&p_lva=3687#
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740145678B574
Let me also give you the site on how to add the linksys router to another existing router.
The linksys has 4 LAN port and 1 "Internet" port on the back - we ONLY use the LAN ports NEVER the Internet port - because your existing router is connected to the Internet - your linksys is connected to the LAN
http://www.kriyayoga.com/love_blog/post.php/368
Feb 18, 2008 | Linksys Wireless-G WRT54G Router
Xbox live/linksys router problem
These documents with pictures should assist you to complete the process. If I were you I might try to understand the second document before using the first.
The generic connection and configuration document
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
This is a good description of possible router options.
http://www.ianarchbold.com/xboxlive/index.html
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 26, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
355 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
