Question about Bose Companion 3 Computer Speakers
Control pod sticky - Bose Companion 3 Computer Speakers
Ihave a 2003 hummer the gauges
This is an extremely common fault on this vehicle platform. You can either see if the dealer has an reprogram update available for this concern, but you would still be charged even if it did not fix the issue(s). Or have the gauge pod repaired-(possibly)-as long as it's a repairable problem. Or you can buy a new unit. If you opt for the repair option, you can either take your vehicle to the dealer and tell them to send out the gauge pod, they will verify the concern for the faulty gauges which will usually run a one hours diagnosis charge plus the labor for removing and installing gauge pod. Or you can remove it yourself and then take it in to the dealer with a sticky note attached with a list of the concern(s) the pod has. Any GM/Chevy dealer can do this. Unfortunately there is no quick and easy fix for this concern.
I hope this info helps!~subyguru~
May 12, 2012 | 2003 Hummer H2
Sticky volume control when turning up and down
The volume control needs a good flush out, take the unit apart to expose volume control pod, buy some electronic contact cleaner and flush the pod while turning the volume back and forth, repeat 2 or 3 times. Note some pods have small slot where you can spray.
Mar 08, 2012 | Audio Players & Recorders
Cruise control will not engage
You will see 2 cables going to the carburetor. One will be the throttle cable and the other is the cruise. Follow the cruise cable back to the vacuum pod and you should see the vacuum lines feeding the pod. You can remove the line at the pod and place another line in that sprout and **** on the hose. If the pod contracts its good, if you **** air the pod has a hole and it is defective.
If the pod is not defective remove the vacuum line feeding the pod and check for holes.
Aug 23, 2009 | 1999 Mercury Villager
Anyway to use Bose companion 3 system without the control pod?
had the same issue. Trial and error - I tried shorting every pair in the control pod dock with a paper clip. Turns out it is totally possible to bypass. You need two: top row, right side to third row, one from the right (below it by two spaces), and second row (there are only two in the second row, connect them). One tells it to turn on, the other passes audio through. I'm only getting sound from the right channel, so probably need to connect one more pair...
Read more: Can i operate my bose companion 3 without the control pod? - I lost my control pod. can i go around it. :: Ask Me Fast at http://www.askmefast.com/Can_i_operate_my_bose_companion_3_without_the_control_pod-qna6342714.html#q3658086
Jun 29, 2009 | Bose Companion 3 Computer Speakers
Logitech z-5500 control pod
http://cgi.ebay.co.uk/Logitech-Z-5500-Control-Pod-FULLY-WORKING-Unit-Panel_W0QQitemZ180332248253QQcmdZViewItemQQptZUK_Computing_DesktopComponents_RL?hash=item180332248253&_trksid=p3286.c0.m14&_trkparms=72%3A1700|66%3A2|65%3A12|39%3A1|240%3A1318
Feb 26, 2009 | Logitech Z-5500 Computer Speakers
Altec Lansing Vs3151 Control Pod
The green connector on the control pod broke. Where can I get a replacement? The orange and black connectors still work and everything else work.
Jan 12, 2009 | Altec Lansing VS3151 Computer Speakers
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Corvette, 1985, lost vacuum to A/C control switch: need vacuum diagram and/or any help I can get...fan is OK, just blows out of all vents at one time.
look for a vacuum pod or tank under the hood. this is most likely where the interior vacuum controls get the vacuum. Does the pod have a line that connects to the intake manifold, or the brake booster? It should., if not find missing vacuum line and repair. Follow the other vacuum line from the pod to the interior, (it is important to find the line going to the interior, as there may be more than one at the pod) is it connected to the controls? it should be. Here is a simplified verbal schematic... vacuum from engine to pod, vacuum from pod to vacuum controlled devices. GM often color codes the interior vacuum lines and that makes them easier to follow under the dash.
Sep 21, 2008 | Chevrolet Corvette Cars & Trucks
5500 d Control pod
Hi Hlth501
So far, is better to get a new control pod. Call the company and see if work for buy it
Nov 25, 2007 | Audio Players & Recorders
Bose Companion 3 Computer Speakers Logo
138 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
