Question about Coby LEDTV1926 19 in. TV
Coby 19 inch led source input will not work keeps scrolling ive tried to set input form tv and remote
SOURCE: I bought a universal remote for a 19
I did not solve the problem, but I was very disappointed that I had to join something to get some help.
Posted on Nov 19, 2009
SOURCE: mode/source set to TV on
Did you solve this? I have the same problem but mine stops on Ch 18.
Posted on Mar 05, 2011
  • 141 Answers
SOURCE: we bought a 19 inch
If you have the model number I might be able to find it for you.
Posted on May 04, 2011
emmanuelboyd
SOURCE: I am trying to program a DirecTV remote for a Coby
The code 10178 worked for my coby 3225 on my DirecTV R64 remote.
Posted on Jun 17, 2012
gator57806
SOURCE: directv remote codes for coby tv
I have a Coby 46 inch tv and the code that works in my directv RC65 and RC65X remote is 11331
Posted on Nov 01, 2012
I changed my tv from cable to an indoor antenna however I cannot get it back to set up to change it over to antenna or air. Help1
Do you mean the Curtis LED1930A 19" TV? If so, first check that the source is set to TV. Use the Source button on the TV (just below the power button) or the remote (to the right of the 0). You can use the up/down arrow keys to change lines in the Input list. Press Enter to confirm the choice if you are using the remote.
Next press Menu on the TV (the third button from the top) or remote (to the left of the 0). Use the left/right buttons to navigate to the Channel heading (the third item from the left). Use the Source key (on the TV) or press Enter on the remote to enter the menu. Use the up/down arrows to highlight Signal Type. Press Enter (or Source) and then use the left/right arrows to get Air. Press Enter to confirm the setting. Now you should be able to highlight Auto Channel Search and search for your OTA channels.
This is shown in the manual. The manual is available from Amazon here: http://s3.amazonaws.com/szmanuals/d29a408ae8fdecdc0547a724183146ef .
I hope this helps.
(The Channel menu is not accessible when the input is not set to TV.)
Mar 29, 2017 | Televison & Video
Can anyone help me figure out how to change the source/input.
You should have a button on the remote labeled "input or source". Every push on that button will cycle through different inputs. Some inputs do not show up on the screen unless something is actually hooked up to that port.
Mar 16, 2016 | Coby Televison & Video
How do I change the input to HDMI
On newer tv's your remote has a button that says source. this is the equivalent of the old (input) button we're all used to. if you don't have the remote that came with your t.v you may have to buy one. or look for buttons on the side.
Feb 21, 2015 | Coby TFTV1923 19 in. LCD TV
Coby tfdvd3295-32in720pwidescreen lcd hdtv with dvd player hdmi input
All TVs have a tuner and a set of AV inputs for connecting other sources. A combi TV such as the Coby has one of those inputs dedicated to the built-in DVD drive. Press the Input button to see the list of sources.
The disc can be ejected either by pressing the eject button on the set itself, or possibly from an eject button on the remote if there's one fitted.
Sep 03, 2014 | Televison & Video
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
My 19" LED Coby tv
Consumercare@cobyusa.com
I looked but no known phone number
Feb 06, 2018 | Coby TFTV3225 32 in. LCD TV
TV scrolls through input sources on its own
To make sure the remote is still working, point the remote to the TV sensor, press couple of times and notice the Red LED is response or not. If the LED blinking, the remote works fine. The suspection now is the main board which is control all the inputs. You can try to get TV back to factory reset, it might help.
Aug 12, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Jan 05, 2008 | Sanyo DS24205 24" TV
Coby LEDTV1926 19 in. TV Logo
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
