Question about VIA DH302 USB 2.0/FIREWIRE 1394 Combo Card Used Item
Via 1394 dh302
Drivers for Windows XP
1394 adapter win xp
1394 adapter gets installed from inbuit drivers from xp , if at all you are using external 1394 port remove the drivers from add remove programs and install again
Sep 30, 2013 | Dell Studio 1537 Laptop
Necesito drivers para w 7 para jvcGR-d350u
The 1394 bus driver was rewritten for Windows 7 to provide support for higher speeds and alternative media, as defined in the IEEE-1394b specification. The 1394 bus driver that is included with Windows 7 replaces the 1394 bus drivers that were included with earlier versions of Windows.
For more information, please refer to this document: 1394 Bus Driver in Windows 7
In addition, according to Windows 7 Compatibility Center, JVC Americas GR-D350 High-Band Digital Video Camcorder is compatible with Windows 7 x32 bit.
You can refer to the instructions in this website and see if the issue can be resolved: Windows 7 1394 Firewire devices not working?
Hope this helps.
Aug 18, 2013 | JVC Video Cameras
Hi there cannot connect i link to my pc no connection on my pc any advice would help
Usually what you would do is buy a IEEE-1394 interface card and install it in your PC in an available slot on the motherboard. You can buy these for less than $20 and with a little tech knowledge about PCs many people can install the card themselves. The IEEE-1394 is called i.Link by Sony. If you are running Windows XP, or Vista, the drivers are already installed. Reboot PC and the new card should be recognized. Use the 4-pin to 4-pin firewire cable to connect camcorder to PC. You will need software to capture your video which should have been supplied by Sony with your camera. For Windows 7, you need to install LIVE Photo Gallery. Your camcorder was setup to work with Windows XP so an alternative may be to just find a friend with an older PC with a firewire card already installed running Windows XP. I just did this very same thing on my PC and it worked. Got the firewire card from Amazon.com for $3.95 VIA brand from Taiwan. I used Windows Movie Maker to capture video. Sony also sells a stand-alone DVD recorder which connects to a camcorder and requires no computer to create DVDs of your video.
Mar 18, 2011 | Sony Handycam DCR-HC24E Mini DV Digital...
How to reformat a notebook laptop with no CD-driver?
Remove the hard-disk - it will usually connect via an IDE or SATA-compatible interface. You can then connect it to a computer (internally, or via eSata / USB / 1394 enclosure). You can then format it from that computer.
When you say no CD-driver, do you mean Driver or Drive?
if there's no CD drive, it should either have a floppy drive (in which case, any system book disk can re-format the HDD), or USB-booting capabilities.
If there's no driver, than a Windows 2000 / XP CD should be able reformat the disk - when you boot from it, it will load drivers off the CD. You don't need to install Windows normally, the recovery console can format disks.
A Windows 95/98/ME boot disk/CD will allow formatting, but only in FAT/FAT32 file systems (you will probably want NTFS, which 2000 and XP can create)
Sep 05, 2009 | Computers & Internet
How do i reinstall my 1394 sys driver ? not on this computor on my wife's
http://www.soft32.com/download_170557.html
here you will find a 1394 net adapter ...which is a driver for ethernet adapter (Lan) if you were talking about IEEE 1394...for fire wire ...this might be different
Sep 02, 2009 | Microsoft Windows XP Media Center Edition...
Driver Audigy sb 1394
I want to simply down load audigy sb 1394 driver without buying the Dr. Detective program...why can't I do this? My son gave me his old computer, but the sound card needs to be re-installed.
Thank,
Tom
Jan 13, 2009 | Computers & Internet
Driver
Please help me with the "1394 net adapter" for Desk Top. with XP OS.
my email: thilak_h@sltnet.lk
thank you
Nov 02, 2008 | Dell lp-n21063-b Network Adapter
1394 adaptor
no you most likely just need to install the drivers for your nic card ... goto the device manager and look under other devices and see if a simple pci networking device is listed .. if it is remove it and run the new hardware wizard .. you will also need to identify the device either physically or by looking up your systems specs ... a useful command line utility is systeminfo in the command prompt ... if it is the driver get it downloaded from you manufacturers site and transferit by cd or stick drive and install it ....
Mar 20, 2008 | Compaq Presario 5000 PC Desktop
VIA DH302 USB 2.0/FIREWIRE 1394 Combo Card Used Item Logo
81 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
