Richo Sp350sf After up dating the computer the Ricoh printer was removed from the computer. Now the printer is working but the scanner is not. No one can help me now. Please help!
old marine
  • 1924 Answers
SOURCE: All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
Posted on May 21, 2008
  • 158 Answers
SOURCE: How to connect ricoh 1035
First, check on the left side of the machine to see if it has either a USB or RJ-45 receptical to plug your computer into. If not, the machine lacks the hardware needed to print from your computer. A Ricoh technician must install it at extra cost. If you DO have either of these recepticals, go to:www.ricoh-usa.com/downloads, to download the manual and drivers you need.
Posted on Sep 02, 2008
SOURCE: Richo 1515 MF Error message: 12320 couldn't find the scanner.
The scanner had been previously configured and did work on another PC that crashed. We used adobe 5.0 to import. (obv this was awhile ago) I remember having this problem then but I don't remember how we fixed it.
It's a MF and the PC can print to it, but I can't get the scanner to communicate.
Any help appreciated.
Posted on Feb 27, 2009
  • 161 Answers
SOURCE: Ricoh MP4000B
this machine should have 2 options
a)scan to e-mail
b)scan to folder
scan to folder is the best solution.
configure the machine-ip,sub-net,gateway & dns
make a shared folder in the pc with password
enter that path and password on the machine or from the web page and save it in the address book.
Posted on Nov 06, 2009
newport74
  • 58 Answers
SOURCE: Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Posted on Feb 27, 2010
Printer Ricoh sp 210 su in error service call sc556
your printer seems overtoned or the toner density is too high regulate it out then switch off an on
Oct 15, 2016 | Ricoh Office Equipment & Supplies
Richo mpc2050 how to hnter to system setting thatis log by another one
1. Login as supervisor.
2. Use system settings, administration tools and change or remove login passwords for mashine administrators or other users.
Apr 12, 2015 | Ricoh Ricmpc2051 Mpc2051 Color Laser...
Richo is200e scanner ADF thinks there is paper in the ADF and asks to clear the originals before trying to scan. We have checked the ADF for paper jam and tried cleaning the unit but it will not clear the...
These scanners will collect alot of paper dust. You need to remove the ADF cover and using compress air and or a vaccum blow out the jam/original photosensor's, I believe there are 4 sensors. Power OFF then ON and try it..
Mar 22, 2010 | Ricoh IS200E Flatbed Scanner
The axe of one gear for a richo scanner is broken
that is happening on lot of new ricoh machines you should order the drive shaft and a hexagonal screws for to be replaced
May 09, 2009 | Ricoh Office Equipment & Supplies
RICHO 2015
Make sure there are no firewalls turned on your computer. All firewalls should be controlled on a router.
Are you using the web interface from the copier to download them?
Mar 09, 2009 | Ricoh Aficio 2015 Copier
This is a message on your PC...not the machine itself obviously? Was this scanner ever configured to work on your PC? If not, then follow this link to my comments to someone else about this machine:
http://www.fixya.com/support/t1718617-ricoh_1515mf_scanning
Feb 27, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
32 people viewed this question
k24674
